anyone else seen an oil pan like this?
Old April 8th, 2014, 07:58 PM
dynamic63's Avatar
bought a 394 and it has this growth on the oil pan. dont know why. looks like a 1qt sump but why would anyone put this on could this be somethin special? other 394 does not have this. also here is numbers on head.thumb drive bob 119.jpg
thumb drive bob 107.jpg numbers look like 065548. any clue?
dynamic63 is offline
Old April 8th, 2014, 09:57 PM
59-59-59's Avatar
Nothing special. Looks like '61 and up 394 had the additional 'hump' on the side of the pan
59-59-59 is offline
Old April 9th, 2014, 04:37 AM
fbonanno's Avatar
Nothing like that on my 63/394. Almost seems like someone was trying to get extra capacity beyond the normal 4 quarts. Maybe it's an aftermarket piece?
fbonanno is offline
Old April 9th, 2014, 04:45 AM
59-59-59's Avatar
D'oh- meant to say I've seen them on 61 and 62 394's
59-59-59 is offline
Old April 9th, 2014, 03:58 PM
citcapp's Avatar
this started with the 57 371 and I have never seen a definition of its use. The capacity of the pan in the 57 is listed at 5 quarts.
citcapp is offline
Old April 9th, 2014, 04:44 PM
Run to Rund's Avatar
My 62 Starfire had it.
Run to Rund is offline
Old April 9th, 2014, 04:55 PM
Barry Jones's Avatar
It almost looks like a welding gas bottle cap !
Barry Jones is offline
Old April 9th, 2014, 05:34 PM
Phantom Phixer
Charlie Jones's Avatar
This "can" added about 1/2 quart oil capacity,without changing the depth or the design of the pan.
It also probably helped cool the oil better.
"Back in the day' I remember neophyte mechanics putting an oil filter wrench on this thing and trying to remove it to change the oil filter.
Charlie Jones is offline
Old April 9th, 2014, 05:58 PM
jensenracing77's Avatar
I had a 62 Dynamic 88 and an extra 62 Starfire engine and both had it.
jensenracing77 is offline
Old April 9th, 2014, 07:54 PM
Phantom Phixer
Originally Posted by dynamic63
Attachment 89475 numbers look like 065548. any clue?
That is the engine unit number. (It has no relation to the VIN )
The numbers started at 001001 so this is the 64,548th engine made that year.
Just before the number should be a prefix letter either an H or J . H= 2 barrel, J= 4 barrel. the engines were painted either red or green. Red was high compression (10.25 to 1) green was low compression (8.75 to 1). There may have been a suffix letter also, none= hi compression, E or L = low compression, S= Starfire.
Your engine would decode to a 2 barrel, high compression engine.
Old April 9th, 2014, 08:13 PM
dynamic63's Avatar
looks like a Gor a 3 ahead of the bolt 065548 after. supposed to be a 61 skyrocket engine. but i never believe sellers. stickers and paint are easy. green 2 bbl motors become red 4bbl motors in about an hour. bought motor and tranny for 350 so i figure i did fair. runs decent compression was very low at first like 45psi left it run in three to five minute bursts over three weeks as to not overheat ( no water) comp rose to 135 respectfully. figure i will install and run on highway and if it dont get to 180 then i will tear it down next winter. right now spendin the dough on the body.( pa car)
Old April 9th, 2014, 09:01 PM
Phantom Phixer
I didn't know we were talking about a 61 engine. Info changes.
Prefix letter; F= low compression, G= hi compression,
Suffix letter; none = 4 barrel, H= 88 hi comp option, E= export.
Seller was right 1961 4 barrel 10 to 1 compression. (Skyrocket)
Old April 10th, 2014, 05:33 AM
dynamic63's Avatar
thank you very much for the information, al
Old April 10th, 2014, 09:53 AM
D. Yaros's Avatar
Is a standard oil pan, and it does make getting the oil filter off/on a real pain!
D. Yaros is offline
Kevin W
February 21st, 2014 06:18 AM
droptopron
April 15th, 2012 04:50 AM
56rocket
November 30th, 2010 06:23 PM
geckonz08
August 21st, 2008 07:58 PM
Quick Reply: anyone else seen an oil pan like this?
