Anyone done a gasser before?
Old Aug 27, 2020 | 02:17 PM
Coastie's Avatar
Stock cars are too boring
ive got a 67 currently with 72 disc brakes up front, and I want to put a straight axle and lift the front end up. I know speedway motors makes complete kits (though idk which one I would need yet), but I was looking for words of wisdom from anyone who's done it.
Old Aug 27, 2020 | 02:19 PM
This chili dog and fries and I did one all afternoon today.
Old Aug 27, 2020 | 02:44 PM
Most of the kits are universal, you need to figure out how much drop and front end weight for the springs.
Old Aug 27, 2020 | 02:49 PM
RetroRanger's Avatar
72 Olds CS
heres a cool looking 67
https://classicoldsmobile.com/forums...t-axle-119721/
Old Aug 27, 2020 | 03:09 PM
70W-32's Avatar
How good are your fabrication skills?
Old Aug 27, 2020 | 03:48 PM
Coastie's Avatar
Non existent. But I have a savings account and a credit card lol
Old Aug 27, 2020 | 05:42 PM
70W-32's Avatar
Well, there are a lot of car shops willing to take your money
Old Aug 27, 2020 | 06:09 PM
72 Olds CS
many here just took a course or two at the local voke tech school and bought a welder (i did) im no fabricator but when i cut something to short i can put it back together !!!
Actually my motivation was my floors, they needed replacement, i pushed myself through that project and i am happy w the results. The welder cost is likely close to what i could have paid a shop for floor replacement so its like i got the welder free. (sorta)
I get a lot of inspiration from watching velocity/motortrend TV,
Old Aug 27, 2020 | 08:20 PM
70W-32's Avatar
But suspension strength is far more critical than sheetmetal tacking. If the straight axle comes loose, someone could die. If he wants to take a good welding course at a local college he might come away with the capability to weld brackets to his frame that will hold up 3500lbs. under braking stresses.
Old Aug 28, 2020 | 07:12 AM
67OAI's Avatar
Old(s)GuysRule
Dang it RetroRanger, I cut it twice and it's still too short!
Old Aug 28, 2020 | 11:42 AM
Bernhard's Avatar
Gasers are cool!
I would not cut up the outer body panels nor convert to a flip front end. Some of the purist might disagree,but I don't think it is necessary to pull off the gasser look.
If that is your 67 in the picture you are well on your way. If you could find a cool intake set up that would ad to the gasser theme
Old Aug 28, 2020 | 02:55 PM
Coastie's Avatar
Originally Posted by Bernhard
Gasers are cool!
Sadly that isn't my car, just what im trying to get. Pic is mine.
Since im doing such a mild lift, im actually looking at lift kits for donks since all I need is the front end. I hate to say it, but it seems like a better option vs all the work for a straight able
Old Aug 29, 2020 | 11:23 AM
Bernhard's Avatar
You have a good start.
Build it as time and money allow and if you don't have to have it off the road for any length of time it will be more enjoyable.
Make sure the car is derivable when you are done, don't build one that is unsafe to drive.
Like I said before Gassers are cool.
Good luck with the build
Old Aug 29, 2020 | 12:17 PM
Coastie's Avatar
UPDATE: After talking to several shops, a straight axle swap seems to be a lot more than I thought due to the frame shape; basically they'd have to remake the frame from the firewall up.
I feel dirty for saying this, but im thinking of looking up lift kits for "donks" (extended control arms, etc) to achieve the 5-7" of lift that I need in the front. The good news is that it shouldn't effect the way the car drives (apart from cornering, but it wasn't great at that to begin with), but I won't have the straight axle which in my opinion, is the only way it would look good
Old Aug 29, 2020 | 12:25 PM
Bernhard's Avatar
What do the guys a Nickey say.
I would spend a lot of time researching before making any decisions.
https://www.hotrod.com/articles/nick...tte-nationals/
Old Aug 29, 2020 | 12:27 PM
Bernhard's Avatar
You don't have to go straight to a straight axle start with simple mods first like period correct rims etc
Old Aug 29, 2020 | 01:20 PM
Or you can do what I did and lift the car a couple of inches with springs. I think the *** end of yours could come down a bit.
https://classicoldsmobile.com/forums...ont-end-53790/
Old Aug 29, 2020 | 01:30 PM
72 Olds CS
That looks good eric!
Old Aug 29, 2020 | 01:55 PM
Coastie's Avatar
Thats what im looking at next. I've already got BB A/C wagon springs all around, so I need an actual lift or something
Old Aug 29, 2020 | 02:21 PM
Can you post a side shot of the car like my picture? What wheel and tire sizes are you using?
Old Aug 29, 2020 | 02:45 PM
Oldsmaniac's Avatar
Not a 67 but very cool.
Old Aug 29, 2020 | 02:53 PM
Coastie's Avatar
16" rims, 28" in the rear, 25ish in the front. I do have air shocks in the back to give it the lift that I can lower a bit, but I was hoping to go with larger tires in the back.
Old Aug 29, 2020 | 02:57 PM
You can try going with tubular fronts and coilover shocks to lift the front. A arm front ends have limits to how high you can go and still get a proper alignment dialed in.
Old Aug 29, 2020 | 04:25 PM
Coastie's Avatar
That's why in considering a kit from here
https://www.universalcarlifts.com/?g...caAlsuEALw_wcB
Old Aug 29, 2020 | 06:05 PM
Bernhard's Avatar
A engineered kit would be the way to go for safety and drive-ability.
Old Aug 29, 2020 | 10:46 PM
Inline's Avatar
My god, that looks _awesome_ !
Skeetman
Suspension & Handling
Mar 5, 2019 01:14 PM
travisbeamon
Apr 14, 2016 05:18 AM
Roger60
Brakes/Hydraulic Systems
Feb 21, 2016 04:33 PM
xerxes600rr
Drivetrain/Differentials
Feb 28, 2010 04:24 PM
cutty
Nov 2, 2008 12:33 AM
