Any tips on cleaning steering wheel?
Old Jun 13, 2011 | 08:03 PM
deaddds's Avatar
I have a 77 Cutlass with the sport wheel and cannot get that gooey, sticky grip feel off the rubber. I've tried Simple Green with a towel scrubbing and its still there. Tried a vinyl cleaner, no good. The auto parts store said to try Goo Gone but got home with it and it says not to use on rubber. Isn't this what the wheel is made of? I don't remember the wheel being this bad but its been sitting a few years. Other than sticky, the outer rubber looks great. How do you get this stuff off?
Old Jun 13, 2011 | 08:08 PM
stevengerard's Avatar
try doing a search, this topic comes up here and there, for the life of me I can't remember what I used, it worked for a bit but it always got sticky again eventually. maybe it was benzene.
Old Jun 13, 2011 | 08:22 PM
rcorrigan5's Avatar
Randy C.
As I recall, you will just have to keep cleaning it from time to time. It's a condition that happens on some steering wheels of that era. I have a '68 442 and a '70 GTO and those steering wheels are fine. But on my '69 442, the steering wheel oozes that same stickiness that you describe and I do not believe there is any cure for it, other than occasional cleaning.
Randy C.
Old Jun 13, 2011 | 08:25 PM
Lady72nRob71's Avatar
I used goo-gone and cured it - for a month or so....
I used that then used light soap and water.
It is a constant battle of the outgassing, aging chemicals. This is the reason why mine is still in the back bedroom and not in the car.
I am thinking of having it wrapped in black leather at a custom rod shop. Costly but goo-less...
Old Jun 13, 2011 | 08:43 PM
69442murph's Avatar
I have used a wax and grease remover about once a year, then soap and water, then a very light wiping of armoral, and it seems to have helped.
try it on a small area first before proceeding to do the enitre wheel.
tim
Old Jun 14, 2011 | 06:12 AM
deaddds's Avatar
I'll try the goo gone and rewipe the wheel with Simple Green and report back.
Old Jun 14, 2011 | 06:25 AM
I've used an aerosol called tuff stuff, seems to clean most of it off. Then I go over with a damp cloth.
Larrys'66
Jan 23, 2014 11:27 AM
1970VistaCruiser
Mar 23, 2013 07:20 PM
lshlsh2
Care and Appearance
Jun 25, 2010 09:35 AM
Flye
Jun 12, 2009 01:21 PM
LangfordBoy
Dec 20, 2008 06:51 AM
