aluminum radiator
A while back a member posted Pepboys having 4 core copper radiators but by the time I got mine it was aluminum. I kept it and put it in the Cutlass when I dropped the 455 in. I had to change the bottom supports and use the 4 core top plate from the 442. The car now runs, on a hot day at about 180-190 with a 180 stat. Radiator fit near perfect and works great. I think it was around $190 and made in Canada.
Have used both of these with good results on 455's says Buick but fit the Cutlass perfectly. You can call them to verify
http://www.speedcooling.com/1968-197...-Radiator.html
http://www.speedcooling.com/1968-197...1-4-TUBES.html
