Alternative for Plastic Chrome
Old Jul 4, 2014 | 02:42 PM
My442's Avatar
Thumbs up Alternative for Plastic Chrome
The raised chrome portions on the plastic dash on my 70 442 were weak, and I used the chrome paint pens that you can buy in hobby stores.
It was OK, and I did not want to spent hours pulling the dash to have it vacuum metalized.
I found a product called Bare Metal Foil. It is a very thin chrome foil that is used in the model car hobby.
With some practice and patience, you can restore the chrome edges on your dash. It actually looks as good as vacuum metalizing.
http://www.bare-metal.com/bare-metal-foil.html
Old Jul 7, 2014 | 03:00 PM
BlackGold's Avatar
Thanks for the tip -- sounds great. I bet it would work on the chrome-plated piping on door panels, too.
Let us know how the adhesive holds up when the car's parked in the hot sun.
Old Jul 7, 2014 | 04:07 PM
X2 on holding up with the heat.
Old Jul 7, 2014 | 04:58 PM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
I agree on the 68 thru 71 Vacuum Metalizing isnt cost effective.I would recommend this.
Strip the IP/Instrument Panel.
Use a paint that has a High Luster Silver and a compatible Gloss Clear Coat.
Enamel to Enamel.
Mask off the areas to remain Silver ..Using a good Masking tape and cut the areas that are to remain silver with an Exacto Knife.Its Surgical.But can be done..Follow up with your IP Color Coat..And Matte Clear ..
Ol' 75" Omega
Aug 20, 2012 04:17 PM
slantflat
Nov 30, 2011 06:19 PM
defiant1
Brakes/Hydraulic Systems
Jul 11, 2011 06:26 AM
diabolic
Aug 24, 2010 10:00 AM
hinz57
Mar 23, 2009 09:57 AM
