Alt. Belt won't shut up!!!!!
Old Dec 1, 2009 | 04:14 PM
Wyze's Avatar
I have a 86 Cutlass, it would squeak for a min or two when I start it up..... Then it broke the powersteering belt, I replaced it, three days later it broke again so I replaced it now the damn car won't stop squilling... So I took the alt. belt off and it stopped when I put it back on it started again.... I used belt dressing but that doesn't help, the belts are tight and not to tight....
CAN SOMEONE PLEASE HELP????????
Old Dec 1, 2009 | 04:21 PM
Wasted's Avatar
I would check to see if your pulleys are misaligned
Old Dec 1, 2009 | 04:25 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Did you remove the AC compressor and smog pump?
If so, that's your problem.
Those brackets have issues when unbalanced.
Wyze's Avatar
Took them off and put them back on... Just gone done a hour ago.... This really is driving me crazy!!!! SMH!!
Old Dec 1, 2009 | 04:26 PM
There are shims that go behind the brackets. Make sure they are all in the right places.
Old Dec 1, 2009 | 04:28 PM
Wyze's Avatar
Hell yeah I did!!!! I called myself not needing that stuff anymore, but that was months ago...
Old Dec 1, 2009 | 04:29 PM
They are iron rings, between 1/2'' and 5/8'' thick.
Old Dec 1, 2009 | 04:33 PM
You have 2 options now really.
Get a bracketry setup from a 68-76 with AC motor, and swap the whole works on, or find 1968-70 non a/c passenger side alternator mount, that relocates it by the fuel pump.
Eightupman on here should have a set or 2 if you want to PM him.
Old Dec 1, 2009 | 04:34 PM
Wyze's Avatar
Is there anyway around putting the AC & smog pump back on????
I also have a 68 and I only have one belt running the Alt. Powersteering & and fan....
Old Dec 1, 2009 | 04:37 PM
Wyze's Avatar
I think I might have a pulley setup from a 72 Rocket, I've gotta look through the garage hopefully I didn't get rid of it...
Old Dec 1, 2009 | 04:38 PM
Old Dec 1, 2009 | 04:41 PM
If you have ALL of the brackets, pump and pullies it may work. but only if the water pump lengths were the same.
Your easiest solution is moving the alternator.
Old Dec 1, 2009 | 04:42 PM
Wyze's Avatar
Good **** Chi Town that's the first time I noticed a pass side mounted Alt...
Old Dec 1, 2009 | 04:45 PM
Wyze's Avatar
Then that will be the direction I'm headed... Just when I thought I was gone give Ebay & Craigslist a rest... Lol...
But notice that the ps pump in the picture is a 2 groove.
307's have a single groove. what groove does your ps pump ride on on your wp pulley?
Old Dec 1, 2009 | 04:48 PM
Wyze's Avatar
The second, the first has the alt belt...
Old Dec 1, 2009 | 04:50 PM
That will probably work out then.
Old Dec 1, 2009 | 04:52 PM
John, on here posted one for sale earlier this week.
https://classicoldsmobile.com/forums...ightupman.html
Old Dec 1, 2009 | 05:00 PM
Wyze's Avatar
it's dirty but??????
Old Dec 1, 2009 | 11:29 PM
mugzilla's Avatar
is Fast Enough ...
Did you spin your alternator by hand ..?
Old Dec 2, 2009 | 05:18 AM
Wyze's Avatar
The Alt is good... The noise seems to be coming from the fan pulley- waterpump pulley....
Old Dec 2, 2009 | 07:40 AM
mugzilla's Avatar
is Fast Enough ...
I'll spray water on the belts and if the noise goes away I know it's a belt/pulley ...
Old Dec 2, 2009 | 08:05 AM
Oldsmaniac's Avatar
Your pulleys are probably mirror smmoth and shiny. Sand them with coarse emory cloth and see if it helps.
Old Dec 2, 2009 | 10:35 AM
Wyze's Avatar
I'm gone try that in a min, soon as I go on lunchbreak... I hope that's it so I don't have to go changing ***** and I did notice my alt belt was shiny when I changed it, but the new belt made the same noise....
Old Dec 2, 2009 | 10:44 PM
mugzilla's Avatar
is Fast Enough ...
Like I said a little spray of water will make the belts grip for a few ...
Old Dec 3, 2009 | 09:43 PM
Wyze's Avatar
NO luck, I sanded the inside of the pulley and it still screams at me!!!
Old Dec 4, 2009 | 05:08 AM
Oldsmaniac's Avatar
I was hoping you would sand all related pulleys?
Old Dec 4, 2009 | 05:11 AM
Col Wickham's Avatar
...should get a life....
You might have a bearing gone somewhere resulting in a little play in one of the pulleys. Once the tension is on it will pull itself off centre and squeal. I had an R34 Skyline (sorry guys...daily driver) that did it. Brand new belts didn't stop it. New bearing did.
Old Dec 4, 2009 | 09:11 PM
Wyze's Avatar
Where would it be the water pump????
Old Dec 4, 2009 | 09:53 PM
You guys have great suggestions, but the problem is the junk 307 parts.
Old Dec 5, 2009 | 11:52 PM
  #31
Wyze's Avatar
I going to a gold rocket, I just gotta drop a 455 in my 68 first!!! Unless you can give me a loan....lol
Old Dec 6, 2009 | 02:13 PM
  #32
Probably not the water pump. You'd more than likely get a grating noise and maybe a little water if it was the pump. Mine was alternator but if your car has air it could be compressor. My alternator wasn't spinning as fast as it should have been but the belt was. Maybe one of your belts is getting much hotter than the others??
Old Dec 14, 2009 | 01:36 PM
  #33
Wyze's Avatar
Now Im not getting a charge and I know the alt is good!!!!! Could the belt be slipping and not allowing the alt to charge the batt??????
Old Dec 14, 2009 | 11:29 PM
  #34
mugzilla's Avatar
is Fast Enough ...
I just fixed my friends 71 ranchero ...
The wire loom goes through a plastic fitting and had separated the wire even though it looked good ...
Autozone or similar will diagnose or even a test light will help ...
I like the gizmo you plug into the lighter socket and has indicator lights on it ...
Old Dec 14, 2009 | 11:42 PM
  #35
If the alternator is good and it's spinning then it should be charging unless like Mugzilla says, the wiring has become disconnected or maybe earthed out somewhere.The belt would be slipping big time if that was the cause and you'd see it.
Check your wiring first.
Old Dec 15, 2009 | 04:08 AM
  #36
Blk71SX's Avatar
rough up the contact area of the belt with 80gr sandpaper or try a new good quality belt. I've seen what should be a good belt squeal and nothing would shut it up for more than a few minutes.
Old Dec 20, 2009 | 05:57 PM
  #37
Wyze's Avatar
twinjracing
Vista Cruiser & Wagons
Oct 7, 2014 09:48 AM
Rios69Cutty
Oct 18, 2012 04:22 PM
American Lead
Apr 20, 2009 12:47 PM
d.smith1
Jan 30, 2008 12:08 PM
