Air cleaner lid gasket
Does any one repo these? I had a lid re chromed several years ago, and of course the rubber seal had to be removed, I have yet to find anyone who reproduces these.
I've never seen an air cleaner with a gasket between the lid and the base, only between the base and where it sits around the carburetor. I've always just set the lid on the base and tightened down the wing nut.
I just pulled the lid of my cleaner and found nothing. If you tighten the lid properly there is not much that can get through that otherwise wouldn't get through the filter. On all my cars I have never seen or used one.
Maybe cause I don't use stock air cleaners.
The non OAI air cleaners have seen them all w them.
However w my W cars not one single chrome lid whether original or non has the that.
I'm not saying they didn't come w it just based on what I have
By George you are right! Talk about learning something new every day. I never noticed it before. There's one on both of my old cars. I've never replaced one, either, but both are in pretty good shape.
X2
QUOTE=Allan R;694595]Are you guys kidding me? Go look at your cars. Pull the lid off the air cleaner and take a look at what's jammed around that recessed ring all the way around. I have never seen an air cleaner lid without that rubber seal.[/QUOTE]
do you have pics of your 31 would love to see them
what color combo is yours?
okay but looks like you are to drive it
The 1970-72 O.A.I. lid doesn't need any foam because it only seals to the top of the air filter rubber end ring.
little hard to follow that, but my W31 has the seal/gasket also. as do 68-72 base GTOs (I'll exclude those 2bbl ones though). BTW, the chrome lid on 68-70 GTO air cleaners is the same lid on 68-69 OAI air cleaners
Let's not confuse the 68-69 O.A.I. air cleaners (which are full air cleaner housings) with the 70-72 O.A.I. air cleaners (where the lid only seals to the air filter element).
why thats a familiar condition. Mine's about the same, although it was running 2.5 years ago until I tore the front end sheetmetal off it for rust repair. Then I moved and sadly, it's kinda sat since then.
#31
The base has paint. Try one of the rubber dealers Steel A&M etc... I did mine a few years ago. Ill have to look to see exactly where I sourced the gasket. Could have sworn it was YO or Fusick.
69CutlassAlex
December 2nd, 2011 08:01 AM
