AGM Battery Charging
Old Sep 18, 2020 | 11:55 AM
Sugar Bear's Avatar
Is it ok to use a 10/2 amp lead acid type battery charger on an AGM battery? Battery would be out of the car and likely just need to be topped-up.
Thanks!
Old Sep 18, 2020 | 11:59 AM
I've used it on two of my batteries on several occasions - a couple times on my motorcycle and a couple times on my zero-turn JD mower with no issues.
Old Sep 18, 2020 | 12:16 PM
VC455's Avatar
Barely Registered
That charger's fine for an occasional top-up on an AGM. But for longer-term or maintenance charging, higher voltage is required during the absorption phase, usually about 14.7 V. Otherwise the battery life is shortened.
The manufacturer will have the exact details for your battery.
Old Sep 18, 2020 | 12:41 PM
Sugar Bear's Avatar
Thanks to both of you.
FStanley
Feb 28, 2023 02:48 PM
Neil Morrison
Feb 28, 2020 06:35 PM
Tedd Thompson
Feb 21, 2015 08:43 AM
76olds
Mar 3, 2014 03:31 AM
VikingBlue
Feb 11, 2012 10:24 AM
