Aftermarket carbs
Old Oct 21, 2019 | 06:47 AM
Copper Nine Eight's Avatar
Aftermarket carbs
Ok, need a little advice on choosing a carb for my 1980 Regency 4 barrel 350.
I want to replace my 4 barrel quadrajet with something new that I will also be able to tune for my future build which will be a 403 with edelbrock heads. Goal being a 400hp/450ft Lbs daily driver. I want to drive my car while building the engine. I know that build is old as dirt but i have had the engine for a long time now and it's something I have always wanted.
Back to the topic. I want a carb I could relatively slap on and go with the ability to build up and tune in the future.
Thanks guys!
Old Oct 22, 2019 | 05:18 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
That will be the best 800 cfm Qjet core but definitely needs to be tuned, especially the idle circuits. Either a Street Demon 750 or one of the Quickfuel 750 cfm carbs would be a couple to seriously consider.
Old Oct 22, 2019 | 05:52 AM
I would usually suggest an Edelbrock Thunder AVS because in my experience they're more streetable than a Holley. If you want a carburetor that you can build later then go with a Holley Street Avenger. Definitely do NOT get a Summit carburetor. They are a POS. I don't know anything about a Demon or Quickfuel.
Old Oct 22, 2019 | 06:47 AM
I actually have a very good Qjet 800 cfm core sitting in a box just for my 403 build. I was getting parts from Cliff Ruggles and reading his Qjet rebuild book but life took a slight left so I gave up. But I might just get back on that. Thanks! I might get the demon 750 just to get on the road.
Old Oct 22, 2019 | 06:52 AM
I was looking at those Edelbrocks. I remembered I have a very good Qjet core that I was building using Cliff Ruggles parts and book. I'm going find a carb to slap on just to get on the road until I finish my Qjet. Thanks for the help man!
MrEarl
Oct 3, 2019 12:42 PM
Matt Joseph
Apr 7, 2019 12:24 PM
Kilmster
Aug 23, 2014 01:25 PM
thenighttrain13
Apr 7, 2013 08:08 PM
