93 Olds Cutlass Ciera + Spark Plug Questions
Old Apr 1, 2025 | 01:49 PM
LudlowLou's Avatar
1. Champion 3013 Platinum Power , pre-set gap is 0.06
2. Bosch 6704 , pre-set gap is 0.040
Most plug mfgs indicate 0.06 gap, why Bosch @ 0.04??????/
Why the difference?
Old Apr 1, 2025 | 02:30 PM
Sugar Bear's Avatar
The Bosch plug is probably used/designed for vehicles that have a 0.040" gap spec and also happen to fit your car. I'd use a plug designed for your car that doesn't need a large gap adjustment. I'd look for an NGK and nothing super, awesome, spectacular, greatest, mileage improving, smoothest running, best acceleration, new and improved version that gives an under the hood fireworks display controlled by the latest app, just the basic plug.
Old Apr 1, 2025 | 02:39 PM
LudlowLou's Avatar
Old Apr 1, 2025 | 02:43 PM
LudlowLou's Avatar
Sounds your an advocate for NGK.....
NGK 3403 @ 0.06 gap. 3 bucks a piece. Just curious about Bosch being different, they are the only mfg that is different.....
Thanks.
Old Apr 1, 2025 | 03:33 PM
Do you have a factory service manual, or at least a Cheater's guide? Set it to the OE spec. GM used huge spark plug gaps (.080) in the late 70s in an attempt to reduce emissions.
Old Apr 1, 2025 | 03:47 PM
Sugar Bear's Avatar
Yes I do like NGK, I'm guessing Bosch uses that plug for multiple applications many of which call for 0.040" gap.
What is your '93 gap spec?
Old Apr 1, 2025 | 05:58 PM
BillK's Avatar
Which engine ? 3.3 or 2.2 ? Personally I have always used AC Delco plugs in GM products.
Old Apr 1, 2025 | 05:59 PM
Supernice88's Avatar
Art S
Isn't there a sticker somewhere in the engine compartment along the cross member that gives the engine specs for the car?
friesjh
May 26, 2022 04:43 PM
Noel Anderson
Feb 27, 2021 03:54 PM
chasman414
Oct 30, 2014 03:15 PM
ralsy
Aug 27, 2010 01:07 AM
craftsman1956
Jul 7, 2010 08:29 PM
