#8 heads
Old Apr 6, 2014 | 08:55 PM
512Lac's Avatar
#8 heads
So I have a olds 350 block 395558-2 with #8 heads. Every were i read seems like nobody like the #8 heads so whats wrong with them? mr cars is just a DD so am i ok or do I need to swap them?
Old Apr 7, 2014 | 06:28 AM
The two things wrong with them are that they are 1973-76 smog heads with smaller ports, and they have very large 80-ish CC chambers vs. about 64 CCs for most earlier small block Olds heads. This makes CR very low. For a daily driver, if the car runs well, don't worry about it. Keep in mind that 1) most of these comments are quotes of other threads and 2) the comments primarily refer to getting maximum output from the engine. What you need on the track is very different from what you want in a daily driver.
Old Apr 7, 2014 | 06:38 AM
stan 65 cutlass's Avatar
mine has 8s on it and runs very strong. yours will be fine
Old Apr 7, 2014 | 07:37 AM
512Lac's Avatar
Thanks guys now i just need to tune my car exhaust smell real bad!!
Old Apr 7, 2014 | 08:40 AM
Whats the year and model? If you have a catalytic converter with rotten egg smell, you're running waaaay too rich. More importantly, that can lead to the converter matrix melting down and plugging the exhaust, so fix it sooner rather than later to avoid another parts bill.
Old Apr 7, 2014 | 09:07 AM
512Lac's Avatar
its a 83 cadillac with a olds 350 block 395558-2 with #8 heads and no cat, has a edlebrock rpm intake and edelbrock 1406 carb. I recently took the car to Meineke and has no exhaust leaks
Old Apr 7, 2014 | 09:32 AM
So what does "smells bad" mean? Overly rich?
Old Apr 7, 2014 | 09:40 AM
512Lac's Avatar
smells like exhaust bad(strong exhaust) after driving fo 20 mins eyes are bloodshot and my head hurts
Old Apr 7, 2014 | 11:36 AM
455man's Avatar
Overly rich can be seen by black smoke. Is it very black around the tailpipe?
Old Apr 7, 2014 | 02:11 PM
76olds's Avatar
Hookers under Hood
Maybe the heat riser isn't opening all the way, Blowing back thru your pcv/ vent tube hoses to the carb when you let off and wind tunneling back into the car. As others said may be very rich
Old Apr 7, 2014 | 09:40 PM
512Lac's Avatar
no black smoke at all. Weres the heat riser????
Old Apr 8, 2014 | 02:57 AM
... after driving fo 20 mins eyes are bloodshot and my head hurts
Does your car have any holes underneath or in the trunk or missing gaskets in the rear?
That sounds like carbon monoxide poisoning, which can be fatal.
I've driven cars with minor exhaust leaks all my life and never worried about them, but when I have a car that makes me sleepy or gives me a headache, I fix it right away.
It's worth a few bucks not to be that idiot on the evening news who poisoned himself, passed out, and hit a bunch of school kids in a crosswalk.
Old Apr 8, 2014 | 03:45 AM
76olds's Avatar
Hookers under Hood
Eric he mentioned he brought into meineke and they found no leaks, Sounds funny with the smell eh !! They heat riser is on the passenger side down at the bottom of the manifold should have a line going to or maybe rotted off. there is a butterfly dohicky that may need to be opened up. Not sure if this could be your problem, I hope others have more suggestions if the system has no leaks an no convertor problem.
Old Apr 8, 2014 | 04:14 AM
76olds's Avatar
Hookers under Hood
You may even have a grommet popped out of the firewall that fumes are getting into the car , I have also seen guys remove the rubber hood sill for more air flow thru the top of the engine......if this is the case and running rich you will defiantly smell it.
Old Apr 8, 2014 | 06:27 AM
512Lac's Avatar
so there is no heat sheild and there is some grommet holes that are unplugged also the heater core from the fire wall but even when you stand back from the car on the outside you can smell it.
Old Apr 8, 2014 | 06:34 AM
512Lac's Avatar
Would it happen to be the the mechanical fuel pumping to much gas to the edelbrock carb to much ps1
Old Apr 8, 2014 | 06:50 AM
It doesn't matter what it smells like from the outside.
You should leave that smell behind you, but your car is sucking it in.
Old Apr 8, 2014 | 07:15 AM
512Lac's Avatar
I'll goto vatozone and see what i can get to plug up the holes
Old Apr 8, 2014 | 10:20 AM
76olds's Avatar
Hookers under Hood
LOL.... and pick up a bottle of oxygen till you get 'r' fixed !!!
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
