72 cutlass washer pump
Old Mar 29, 2010 | 09:32 AM
ELECMAN's Avatar
Having a problem with the washer pump getting no fluid to the nozzeles replaced the pump changed the hoses,removed the filter on the bottom of the tank even pulled the main hose of the washer pump to see i had fluid after the cycle nothing.what the next step to take and what wires should i test to see if the washer sw is giving power to the pump.
Old Mar 29, 2010 | 09:45 AM
When you replaced the pump, did you use a pin to hold the pump drive cam in the correct position when you bolted the pump on? Can you hear the solenoid click when you press the wash button? Have you verified that the inlet screen in the tank is clean? I recently had to drain and scrub the washer tank on my 84 because there was some sort of spooge in the tank that continually clogged the inlet screen.
Old Mar 29, 2010 | 10:03 AM
ELECMAN's Avatar
The two wires on the pump one reads a hot and the other I think is a ground right and does the washer sw put out a neg or a positive
Old Apr 13, 2010 | 06:11 AM
ELECMAN's Avatar
The problem Im having is I cant get the coil to pull up the lever so the washer cycle starts,If I pull it up manually the washer cycle begins, what are the reading on the two wires going to coil suppose to be or any input
Old Apr 13, 2010 | 08:50 AM
D Appeldorn's Avatar
i have 4 wires, 2 goes to the whiper moter and 2 to the pump, the yelow on mine is the positive and mine has a light bleu and dark bleu that are negative i think.
so your whipermoter is contected with yelow black and light bleu, and your washer with the same yelow (split) and dark bleu.
this is of a 69 schedule, so it can be differend. The yelow wire is conected to the fuse block
i bought me a 69 chassis and body book of fisher and helped me fine.
even got from my brother in law a dvd of the same books.
so i have the books at my garage and dvd at home
it even say's wich wire it should be on the fuseconection under the hood at the fire wall.
Make's it a lot easier, to work on the car do
Old Apr 13, 2010 | 04:09 PM
ELECMAN's Avatar
BOTH WIRES GOING TO THE WASHER PUMP ARE YELLOW AND BLUE THE YELLOW IS POS AND THE LIGHT BLUE IS POS TO PULLED THE PLUG BEHIND THE WIPER SWITCH BOTH BLUES ARE HOT BLACK i THINK IS NEG.DOESNT MAKE SENSE
Old Apr 13, 2010 | 10:47 PM
yes your right the bleu from the washer buton is hot, but your washerbuton if you press it it makes contact with the ground to work.
it goes from yellow back in bleu to the buton and when you push the buton it makes contact to ground to work.
i had to rewire my car do, i didn't had the washermoter nor the pump and somone cut the wire's.
Had to rewire and check my chassismanual fisher book, with out it i did'nt get it work.
i bought a repro moter and pump, and had to chains the wires several times on the moter to work.
But it works now
Old Apr 13, 2010 | 10:52 PM
3 wires on the whiper moter, low, high, ........ . neative or positive o don't know.
motor is grounded to the body.
1 screw of the whipermotor should be a cupper clip that conects the whipermotor to the body
yellow is + from the fuse block, i think the black and bleu ar those low and high
Apr 23, 2013 06:16 PM
pcard
Jan 12, 2012 06:27 PM
Chumley
Jun 19, 2008 07:36 AM
bjtstarfire
Jan 24, 2008 10:42 AM
Big Joe P
Apr 15, 2007 04:05 PM
