72 cutlass Top motor
The question I have is that I notice that there is air in the hose between the motor and the cylinder is that normal and what kind of fluid is used in the conv top motor thanks.
I, too, have some air in the lines and the top runs fine.
Only odd thing is that if you stop it coming up or going down, it will slowly move on its own (by its own weight), unless it is balanced in the center position.
Not sure if that is normal, but it runs fine and I would rather not try to fix something that is not really broke. You know how that goes...
Dextron ATF is recommended in the service manual.
GoBigRed
Brakes/Hydraulic Systems
15
October 5th, 2015 01:00 PM
Southern_Hospitality
October 12th, 2011 06:55 PM
October 12th, 2011 08:01 AM
1969goatman
September 8th, 2010 02:08 PM
