72 cutlass oem ram air hood
The pop up spring isn't mounted on the hood.....it's a "spring" that looks nothing like a spring and it's held onto the top of the radiator/core support with two bolts.
You probably already knew that since you have an Olds A-body but maybe yours is missing.
Do these hoods use the same hood springs as the Cutlass S hood? Not the pop spring but the actual hood spring. Im pretty sure they use different springs or no spring but wanted to double check
oldsmobilty
November 30th, 2013 09:55 AM
