72 cutlass oem ram air hood
Old Oct 28, 2011 | 05:33 PM
ELECMAN's Avatar
I wanted to know if this hood uses a hood pop up spring
Old Oct 28, 2011 | 07:32 PM
2blu442's Avatar
If I'm following your question right, yes the factory hoods still have same spring that pops the hood up when you pull the release lever by the license plate. John
Old Oct 28, 2011 | 09:05 PM
70Post's Avatar
The pop up spring isn't mounted on the hood.....it's a "spring" that looks nothing like a spring and it's held onto the top of the radiator/core support with two bolts.
You probably already knew that since you have an Olds A-body but maybe yours is missing.
Old Oct 28, 2011 | 09:13 PM
Vega's Avatar
Do these hoods use the same hood springs as the Cutlass S hood? Not the pop spring but the actual hood spring. Im pretty sure they use different springs or no spring but wanted to double check
Old Oct 28, 2011 | 09:26 PM
oldzzy's Avatar
wait.... what....
They use the same hinge springs
camshaw
May 4, 2015 11:53 AM
oldsmobilty
Nov 30, 2013 09:55 AM
milehigh
Sep 17, 2012 08:11 PM
leadfoot067
Apr 19, 2010 08:31 PM
4-ever-olds
Jan 21, 2010 07:03 AM
