72 CS Installing a rear sway bar and lower control arms
Going to up grade the rear end with a new sway bar. I bought the the lower control arm box pieces to weld in. Has anyone had any problems?
You may/may not need shims between the bar and the control arm. Kind of a case-by-case issue. https://www.summitracing.com/parts/o...+5ba28fb7a12a5
Insanely-high priced.
Greg Rogers
37
November 7th, 2014 07:39 AM
