71 Cutlass Conv Questions
I have a 71 Cutlass Conv that was hit in rear drivers side and I need replacement sheetmetal.
Does anyone know of a company that makes replacement tail panel section ?
Also rear main frame damaged on drivers side. Are all Cutlass frames the same say from rear drivers wheel back ? I know there is a different convertable frame of course but are all A body frames the same in back?
For a trunk pan and drop offs what year and models can I use, are A body trunks all the same?
Good luck with your repairs. Within the past month or so one of the members listed NOS convertible quarters for sale on this site.
here is the add for the quarters.....if still available
https://classicoldsmobile.com/forums...quarter+panels
Not sure if you are interested. But this add is up on Craigslist in Atlanta GA. set of GM NOS convertible quarter panels.
https://atlanta.craigslist.org/atl/p...245651113.html
Thanks guys that replied. Frame is bent in more than one place for sure? I need to get a new frame and tub or switch to a hard top conversion. Could fix but major sheetmetal work. Any leads on a dry frame and or tub would be great.
Flgaurban06
Cars Wanted
September 21st, 2012 06:36 AM
The_German
August 28th, 2011 08:18 AM
