71 Cutlass 455 header issue
Old Jan 30, 2017 | 03:25 PM
sand442man's Avatar
Building a 71 Cutlass convertible. Factory air car. Just installed a 455 and stainless headers. Today I started to install my air/heater box on the cowl and I can see it is super tight to the headers. I can just run a piece of paper thru the gap. I am guessing this is not right. The air/heater box is made of plastic and will melt once the headers heat up.
I'm sure I can dent the header a 1/4 inch or so but that will still be really close to the box.
Anyone run into this issue? What is the solution? I have a non air unit I can install but was hoping to keep the air conditioning.
thx
Old Jan 30, 2017 | 03:37 PM
BlackGold's Avatar
What brand and model of header? Were they advertised as fitting a car with A/C?
Old Jan 30, 2017 | 03:58 PM
sand442man's Avatar
I don't know either answer. The headers came with the 455 when I bought it. Is there ac and non-ac headers?
Old Jan 30, 2017 | 04:26 PM
BlackGold's Avatar
Some companies might make a header model which doesn't care if the car has A/C or not. Others might optimize a header model for, say, racing and expect that the car does not have A/C.
Old Jan 30, 2017 | 04:59 PM
Lee_A's Avatar
Remove the evaporator case, and install a VintageAir system!
Went through all kinds of crap, trying to get decent headers on my 455. Going to VintageAir would have made it a lot simpler, and cost less in the long run.
Old Jan 30, 2017 | 08:33 PM
I don't think your set has equal length tubes. You may need to take a small piece out of the vertical section of that header tube. Heat and bent the horizontal section down and reweld it. Then polish them back up.
Old Jan 31, 2017 | 09:31 AM
ronskal's Avatar
If I was in your shoes and judging by the high quality headers you have I would try and modify the AC box instead of the headers. Since the headers are stainless, you would have to get a shop to re-weld them with a TIG welder.
Cut-out the area and glass-in an inward relief to clear the exhaust? Your box does not look installed yet so try that. You could also bond in a metal heat shield on top of the relief you made. Wrapping the header is not a first option, but will work OK with stainless (after you make the relief).
Upgrading to Vintage Air is the ultimate best fix but at $1500...............I want do it next year on mine.
Old Jan 31, 2017 | 02:43 PM
442Harv's Avatar
It must be the brand of headers, or wrong ones for that car. I had 70 with AC, and I did not have that problem. They were Doug Headers. Could it be you have the wrong motor mounts? Setting to high?
Old Feb 2, 2017 | 09:00 AM
sand442man's Avatar
Does this motor and frame mount look correct?
Old Feb 2, 2017 | 09:20 AM
Kennybill's Avatar
The convertible is based on the Supreme and everybody knows that headers won't fit on a Supreme. Just kidding, I thought I'd bring up the old rumor. I think it is the brand of headers. They look like the stainless steel headers that is selling for $144 with free shipping. Your either going to have to "massage" them then wrap that area or get another brand or do something with the AC box, or get a set of WZ manifolds. I'd massage them. I'm planning on buying a set for a 1972 Supreme myself. I won't have your problem because my box is gone. There's another thread about these Chinese Stainless steel headers or check them out on Ebay. Good luck
Old Feb 7, 2017 | 06:51 AM
ronskal's Avatar
That engine mount looks cracked. Engine is also shifted upwards possibly causing your problem.
Old Feb 7, 2017 | 09:17 AM
rjohnson442's Avatar
Mr. Johnson
Hit the gas real hard once and you won't have to worry about the gap anymore, it will get bigger on it's own :O if the car had a 350 in it before get 350 motor mounts for the 455. Or get the hammer out and create some HP if not worried about the finish.
Old Feb 10, 2017 | 03:35 PM
sand442man's Avatar
Well, I spliced out 1.5 inches and beat the snot out of it and tigged it back together. She ain't pretty but this should do the trick.
Before I could only slide a piece of paper between the header and air box. Now I can fit my fat fingers in there.
Old Feb 10, 2017 | 03:38 PM
Sometimes ya gotta do what ya gotta do. They make stainless clamps similar to tiewraps that maybe a bit prettier.
Old Feb 10, 2017 | 04:10 PM
76olds's Avatar
Hookers under Hood
Looks pretty dam good to me. You'll both be breathing much better after beatin' the snot out of it lol.
Put-r-ther good job.
Eric
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
john71
Aug 1, 2010 10:22 AM
geckonz08
Jul 15, 2009 11:01 AM
68conv455
Jan 3, 2009 07:40 AM
