71 cutlass/442 wheel well patch
Old Jan 13, 2013 | 08:40 AM
The Bug Man's Avatar
Does anyone make a sheet metal patch for the outer edge of wheel wells? The only rust i have to deal with on the entire car is the outer inch of three wheel wells. That's it on the entire car. I hate to buy three quarter skins and just use an in or two aroung the whell wells
Old Jan 13, 2013 | 10:11 AM
Nope. Just the partial quarters.
Old Jan 13, 2013 | 10:16 AM
coppercutlass's Avatar
Chevy budget Olds powered
If you post pics of the area i think we can all guide you in the right direction. sometimes replacing the quarter is the way to go and sometimes it's worth the effort to fabricate a pacth panel.
Old Jan 13, 2013 | 11:51 AM
marxjunk's Avatar
some one makes a partial, because i have a pair, they came with a parts car they have the rear lower 1/4 piece and the wheel lip..i will see if theres a name on them, they are actually pretty decent pieces
Old Jan 13, 2013 | 12:24 PM
2blu442's Avatar
If its a small area... I had a friend restoring a 1972 Cutlass convertible. He had rot around the wheel well lip and I gave him a front fender to cut up. I don't know how much of it they used but his body shop turn out a product that look nice and correct.
John
Old Jan 13, 2013 | 03:18 PM
EVERYONE sells the partial quarters. No one sells just the wheel opening lip.
Old Jan 13, 2013 | 05:40 PM
Heres some pics
Old Jan 13, 2013 | 06:17 PM
make sure they are not loaded up with filler. If that is the case looks like a pretty much straight forward repair keep it small and take your time and you should be able to turn out a good product. I do like the fender idea joe mentioned.
Old Jan 13, 2013 | 07:44 PM
OldsMotion's Avatar
OldsMotion
Rumor has it that a front fender lip is the same contour as the opposide quarter... I've cut some out of rotten damaged fenders, but not tried to work them in (yet)
John
Old Jan 14, 2013 | 04:58 PM
ziff396's Avatar
Are you sure that that is as far as the rust goes? Or just visual.You might want to do a little further inspection before deciding on what approach to take. Once you start grinding or blasting, all sorts of things can pop out at you. If the wheel lips are gone, I would think that there is more that is not seen.
Old Jan 14, 2013 | 05:24 PM
Danny Boy's Avatar
1972 98 & 1984 H/O
Get yourself some fender flares (to cover up the rust) and fat tires!
Old Jan 15, 2013 | 05:29 AM
I'll be chipping off the bondo and getting the ol' DA sander going tonight. Will know more then. Will post pics of what I find
69442murph
Jan 28, 2015 07:36 AM
CutlassS1972
Body work
Aug 21, 2014 09:06 PM
The Bug Man
Body work
Aug 15, 2013 12:53 PM
The Bug Man
Body work
Jan 15, 2013 06:58 PM
1965cutlassragtop
May 17, 2011 12:18 PM
