700r in my Oldsmobile
Old Oct 27, 2013 | 03:58 PM
quentinnw2's Avatar
Hi I need some help thinking about going with a 700r I have a TH350 with 22-2600 stall in my 72 cutlass and I have a 350 Oldsmobile motor my cam spec 520/523 lift at 60 mph my rpm is 3000 I think is to high and I have a 3.42 gear do u guys think 700r would be good thanks
Old Oct 27, 2013 | 04:22 PM
BLUE72RAGTOP's Avatar
An overdrive would be nice with 3.42's but you may not like the drivability of the 700 with that combo. It has a really low 1st gear good for getting off the line with lower numerically gearing, but a little too low for yours. Also, you'll likely need an adaptor for a non-chevy application. Have you thought of a 200 r4 with a B O P pattern?
Old Oct 27, 2013 | 05:46 PM
quentinnw2's Avatar
700r
So you are saying that 3.42 gear wouldn't be a good match with the 700r and yes I have thought about a 200r4 they charge almost double to bulid a good 200r4 than the 700r I want to be able to ride the highway because now my rpm is at 3000 at 60 mph
Old Oct 27, 2013 | 08:34 PM
quentinnw2's Avatar
Who has a reliable 200r4
Old Oct 27, 2013 | 11:36 PM
Check your tach, you should be lower than those rpm's @ 60 mph. I was running 3.42's in my '71 Supreme, and was turning 3200 @ 70 mph with a new tach.
Old Oct 28, 2013 | 10:07 AM
tmaleck's Avatar
I have a 700R4 with a stock 330 in my 67. I just put a 4.10 rear gear under the car. With 27 inch tall tires and the converter in lockup, I am at 2300 rpm at 60 mph. My spreadsheet predicts you would be at 1850 with 26 inch tires and 3.42 gears using a 700R4
Tim
Old Oct 28, 2013 | 04:01 PM
jag1886's Avatar
A 2004r shouldn't be twice as much as a 7004r to build, both transmissions need a lot of work to live behind a healthy V8. I don't like the idea of having to use an adapter plate with the 700 when the 200 will bolt right on. I did a 2004r in my 65 with a 3:90 gear and it works great. Can't tell you much about RPM's as I wouldn't trust my stock Olds tach any farther than I could throw it.
chevyking
May 31, 2018 09:45 AM
tcolt
Feb 16, 2016 11:17 AM
BLACKCADDY
Jun 2, 2015 09:38 AM
wmachine
Dec 30, 2009 05:55 AM
oldsmohaulic
Dec 18, 2009 11:02 AM
