70 Vs 71 442 455 Heads
Are the intake and exhaust valves the same size on the 1970 442 455 E heads compared to the 1971 442 455 G heads. Why is the compression 10.5:1 on the 1970 and lower on the 1971 442 455? What is the compression on the 1971 455 442?
Olds dropped the compression ratio from 1970 to 1971 by using pistons with larger dishes in them, while keeping the head combustion chamber volume the same. '71-up 350 and 455 engines were rated 8.5:1 compression ratio.I think this was due to the introduction of unleaded lower octane fuel and stricter emissions standards.
Note that not all E or G heads got big valves. In 1971, only 442s, Toros, marine, and irrigation engines got big valves. Other G-head engines got small valves.
64 CUTLASS KEN
December 7th, 2020 06:43 AM
ut442
March 9th, 2012 11:57 AM
