70 442/w30-a/c rear axle ratios
Old November 21st, 2013 | 07:54 PM
  #81
70W30Jim's Avatar
Hello Everyone,
I just stumbled on this post and wanted to add my two cents as this is an interesting topic. I own a 1970 W30 w/AC and I have TM 3:42 which my car came and to best of my knowledge was never messed with. I have the broadcast card as well. The vehicle was mfg last week of Oct '69 and the rear end has a D/C of K12 (Sept 12th 1969) from what I've been told, so in theory this would be consistent as original to my car. In High School I removed the original, put it storage and installed a 3:91 rear end from a wrecked 442, as I wanted to be quicker on the street, if you know what I mean....So I have my original 3:42 rear end, the 3:91 and also a complete W27 which I will install when I do a concourse restoration. This just adds to the mystery.....
Old November 22nd, 2013 | 04:33 PM
  #82
66-3X2 442's Avatar
Originally Posted by 70W30Jim
Hello Everyone,
Well,here's another example of the 3.42 with A/C in a 70 W-30. If you have the broadcast card,isn't the rear axle id code on it? Let us know what you have. Thanks for the info.
Old November 22nd, 2013 | 06:06 PM
  #83
70W30Jim's Avatar
Hello,
No axle code noted on the broadcast card for my car, is there supposed to be one?
Jim
Old November 22nd, 2013 | 06:43 PM
  #84
66-3X2 442's Avatar
Hello,
Jim
I'm not familiar enough with the cars with broadcast cards to know. Maybe somebody will see this that knows and will give some idea. I know it will not say the actual ratio but may have the TM code for the 3.42.
Old November 22nd, 2013 | 06:55 PM
  #85
jensenracing77's Avatar
The broadcast card is from the body plant so I don't think the axle code should be there.
Old November 22nd, 2013 | 09:52 PM
  #86
stevengerard's Avatar
I do not recall an axle code any any of the broadcast cards I have
Old November 22nd, 2013 | 11:50 PM
  #87
well Chad just posted a "Production B" card and it shows an axle code.
https://classicoldsmobile.com/forums...-w-30-a-2.html
Old November 23rd, 2013 | 08:56 AM
  #88
GAOldsman's Avatar
"Car"mudgeon
Would the '70 p-o-p show the axle code? I know the earlier ones do and the later ones don't.
Old November 23rd, 2013 | 09:29 AM
  #89
wmachine's Avatar
Trying to remember member
'68 was the last year the POP had engine, trans, rear (and more) info on the POP.
Old October 17th, 2023 | 07:38 PM
  #90
66-3X2 442's Avatar
I am going to resurrect this thread because it has happened again. I bought a 70 442 Conv. 4 speed with A/C from a buddy who has owned it since the 70's It's a matching number car built in Linden,NJ. I have it in my buddies shop for some leak repair & exhaust repair. I went down to see what rear axle it had & I already knew it was a posi because of the tag. We got to cleaning and scraping and found the code-TM. This is the second car that I haver owned that has a TM code 3.42 rear axle which is supposed to be a no no. I went back to my buddy and asked him if he ever had the rear axle out or changed and his answer was no he hadn't. Here we go again.
Old October 17th, 2023 | 08:08 PM
  #91
Andy's Avatar
And-you found the matching vin derivative on the trans on the passenger side of transmission..another anomaly..
Old October 17th, 2023 | 08:18 PM
  #92
66-3X2 442's Avatar
Well that's debatable. With my research all I could come up with was the right side stamping. I asked the question here about the Lansing built cars stamping and all I got was ........crickets.
Old October 18th, 2023 | 04:56 AM
  #93
m455sx's Avatar
Olds Nut
If the car hasn't been restored- i bet there is at least 1-2 build sheets to be found.
Old October 18th, 2023 | 07:09 AM
  #94
SY2455's Avatar
Our 70 W-30 with AC has the 3.23 posi that was in it. With the AC cars as built the 3.23 was the only option do to Oldsmobile pulley drive ratio as told to me by the dealer parts manager (Who use to race Oldsmobile). Having said all that, it was quite common for owners to swap out the entire differential for 3.42 or even 3.91 as in my case. When the group that I used to run with did this we would just remove the AC belt. 1 of the guys ( I will called him Randy ) didn't remove his belt on a night of racing at Orange County International Raceway and on the way home his AC compressor locked up on him.
I still have my spare 3.91 differential however I need a yoke for it after a hard 1st to 2nd shift twisted the driveshaft in half and broke the yoke while running in another car. The W-30 currently has the 3.23 gear differential back in it.
71supreme
Drivetrain/Differentials
23
September 27th, 2013 06:19 AM
garys 68
February 16th, 2012 08:59 PM
martine
16
September 13th, 2007 11:12 PM
thomaswatk
March 22nd, 2007 02:31 PM
69olds350
November 9th, 2006 08:32 AM
