70 442 question
Old May 7, 2019 | 06:39 PM
Gmcdually's Avatar
70 442 question
Stumbled upon a 70 442 with build sheet . I am sure this has been asked before , but what would need to be on there to verify w30 . Thanks
Old May 8, 2019 | 03:44 AM
scrappie's Avatar
Where do we start:
Striping, badging, OAI, FE2 HD suspension, F Heads, 7040258 or 7040256 carb, aluminum intake, limited slip rear. The V.I.N. should have an M (Lansing) 1111979 or 1111977 distributor. OW auto trans tag or Muncie.
These are just some things to look for but Im sure people will chime in. Keep in mind all these parts could be obtained and put on a car built in MI technically. Documentation is would be key but that too could be faked I guess? Original build sheets from Lansing are rare but that would good documentation and the holy grail of paper work would be the original broadcast card that will have the VIN and W-30.
All this stuff could be faked depending on the level of knowledge, skill, fraud and deceit so one must look at the whole picture.
Lets see what your looking at so the jury can give an opinion.
P.S.
Just re-read your post and I missed that you have a build sheet. Some things I mentioned will be on the build sheet but not all.
Old May 8, 2019 | 03:54 AM
rand5204's Avatar
If it has a build sheet, it likely isn't a W30. All W30's were built in Lansing and it's been pretty well established on this forum that most paperwork, including all build sheets were stripped out of all of the cars at the end of the assembly line. I don't believe that anyone has yet documented a Lansing built car with a build sheet. If you have one the car was likely built in either Fremont, CA or Linden, NJ. The plant location will be on the build sheet and coded into the vin of the car
Old May 8, 2019 | 11:23 AM
gglow's Avatar
Do you have a build sheet or a broadcast card, this would help?
Old May 8, 2019 | 02:02 PM
Gmcdually's Avatar
Thanks all, looks like not a W30.
Old May 9, 2019 | 05:14 AM
rand5204's Avatar
Your car, like all of mine, was built in Linden, NJ. Looks like a pretty nicely optioned car. One question on the build sheet. The very last option listed is Y68 Color Comb, and then the rest is cut off. I have exactly the same thing on one of my build sheets but the rest of the phrase is also cut off. What is the entire description for the Y68 code? I know it's for an unusual color combo but curious how it's actually listed. What is the color combo for your car? It's cut off on the top of your pic. Interested in knowing why it's considered unusual. In my case it was a Sherwood Green car with a white convertible top, a saddle interior and gold stripes.
Old May 9, 2019 | 02:35 PM
Jacoz70442's Avatar
Cool find! Mine was a Linden car as well. 111011 sequenced. Found my build sheet inside the upper portion of the notch bench seats when removing the covers.
ostricker
Apr 19, 2019 10:50 AM
Demonator666
Hurst/Olds
51
Jun 18, 2012 07:15 PM
kbdecatur
May 2, 2012 03:56 PM
W70442
Jan 24, 2011 05:37 AM
plu442
Sep 23, 2010 01:17 PM
