69 Vert 1/4 Window weatherstripping ?
Old Jun 16, 2021 | 08:36 AM
Phoenix8990's Avatar
Having cleaned up the window regulators and replaced the rollers things now work nicely. To top off I finally received the weather stripping set that was back ordered. I have had this apart for a while and as I try to fit the weather stripping in I can't tell which piece goes on top of the other. The pinch molding or the new weather stripping. They both seem about the same size and who knows over the years if the pinch molding has been adjusted. I have looked through the manuals for a detail but have had no luck. Can someone send a pic showing "who's on top" ?
thanks.
Old Jun 16, 2021 | 10:24 AM
442Fred's Avatar
Your window sweep is not the same as the original style. PUI makes one close although it takes some effort to make it fit correctly.
Old Jun 16, 2021 | 12:35 PM
These actually are from PUI, but they just don't seem to sit right. Either the pinch molding needs to be opened up a bit or the seal closed? The pic answers my question and looks very nice. thank you.
Old Jun 17, 2021 | 11:40 AM
acavagnaro's Avatar
Yeah, the side window beaded trim slides into the female slot of the top molding.
Duneracer
Oct 9, 2017 07:57 PM
pfergy600
May 10, 2015 07:39 PM
Johnd
Body work
Mar 29, 2014 05:29 AM
drepreston1
Aug 11, 2013 04:25 PM
rz66046
Nov 25, 2012 07:59 PM
