69 air cleaner paint
Old Jun 3, 2018 | 04:08 AM
abrasv's Avatar
69 Cutlass S with a gold 350 engine and off color red air cleaner. Air cleaner needs re-painted and need info on what color of red and where to buy?
Thanks all.
Old Jun 3, 2018 | 07:55 AM
Indy_68_S's Avatar
http://www.fusickautomotiveproducts....?number=AF150S
http://www.supercarsunlimited.com/Re...nt.-d2100.aspx
https://classicoldsmobile.com/forums...ing-paint.html
Budget option: Rust-Oleum 249068 Satin Paprika spray paint. Very close in color but a bit flat in sheen.
Old Jun 3, 2018 | 08:36 AM
tva442's Avatar
See the other CO thread Indy_68_S posted for pic of my air cleaner using the Supercars paint.
However, if yours is a Cutlass with a 350, believe the air cleaner should be black, not red ?
Old Jun 3, 2018 | 08:40 AM
Indy_68_S's Avatar
2bbl = black
4bbl = red
Changed to all black in '70 (IIRC)
Old Jun 3, 2018 | 08:53 AM
Big Daddy Spo's Avatar
Dupli-color Red
I found that the Dupli-Color DE-1632 Chrysler Red is a very close match to the original color. It is easy to find at most auto part stores so no special order or shipping charges. It is their ceramic heat paint which is good to 500 degrees. I used their grey primer as a base so the color would stay bright. This is the air cleaner I did for my 64 Cutlass with a 350. I like how it came out.
Old Jun 3, 2018 | 09:07 AM
4speed455's Avatar
Originally Posted by Indy_68_S
2bbl = black
4bbl = red
It’s actually:
Low compression = black
High compression = red
I have a 68 455 2bbl high compression motor with a red air cleaner.
Old Jun 3, 2018 | 09:59 AM
Indy_68_S's Avatar
Originally Posted by 4speed455
It’s actually:
Good info. Thanks.
Old Jun 3, 2018 | 12:29 PM
tva442's Avatar
It’s actually:
Thanks. I guess I never noticed that difference on small blocks.
Old Jun 3, 2018 | 07:43 PM
cheven's Avatar
WOW thats red .....wait till the wife see's her ironing board !!
Old Jun 3, 2018 | 08:51 PM
You know it! Works well when I can't hang stuff, plus easy portability for keeping things in the sun. All she said was I guess I don't need to iron anymore. She did end up getting a new one out of it. But all in all a great paint bench.
painterbrad
Jul 15, 2019 03:26 PM
f85 rocket
Jul 29, 2016 12:51 PM
Lady72nRob71
Paint
41
Feb 13, 2012 03:05 PM
Cameo White
Hurst/Olds
Nov 27, 2008 06:34 PM
Want-A-Vert
Jan 22, 2007 09:44 PM
