69 or 70 442, 455?
69 or 70 442, 455?
Hi all.
I have had this engine for a few years.
I pulled it from a 70 442. correct W-Z's,
Had the coreect OG 400 behind it. Etc...
But it did have a 398662 D2 intake, 68-69
and C heads. I am tring to decipher the pad #.
It is 39M342368. On the back of the block it is
a F-1 unit. Beside the right side of the dist hole are
the number 4 and below that, a little right of that #
is a #43.
Confused yet? Yeah, me too.
Any help is appriciated guys, and thanks again, Adam.
is a #43.
Hi all.
is a #43.
is a #43.
Hi all.
is a #43.
is a #43.
The 442 has been gone awhile. I had the vin #'s
around here some where, I remember that I ran them
to make sure it was a 344 car, and it was.
I don't know where to check on the tranny, but i still
have it and I can check. I also thought that the engine
was a 69 455, someone will hopefully chime in, Adam.
Yep, that would do it although the intake would not be correct. The 342368 following the 'M' should be just the basic production numbers that would match the last 6 numbers of the vin of the original car it came from. Although not an original 1969 H/O block, the 342368 does fall into the early portion of the series of vins from 1969 H/O's so the block was around at the same time but probably made it into a Delta 88 or somthing of that nature.
Thanks again for the info guys.
Now my curiosity is up. The engine I have built
for my 69 is a 68 F-2 block. Also 39MXXXX on the pad.
Again by the dist. hole, molding # 2, with a very large
# 204 under that. Does that mean anything?
Also, how can you find where they were forged?
The engine I have built for my 69 is a 68 F-2 block.
"68" and "F-whatever" on the block's rear face are not significant nor do they indicate the year of [whatever].
3 = Olds car
_9 = 1969 Model Year
__M = Michigan assemble plant [Lansing, home of Olds]
___101123 = Vehicle's sequential serial number
Mold number, loosely correlated with calendar years since that type block began to be made.
with a very large # 204 under that. Does that mean anything?
204 is the Julian Date of the casting.
204 is about 23July- so July of 1968 for an early production 1969 Model Year would be most likely.
They what?
Blocks are cast, not forged.
3 = Olds car
They what?
sx455raidercelticfan
November 23rd, 2010 05:45 AM
SKINNY IL
May 14th, 2010 07:12 AM
