69, 442, Triple Black, 4 speed, nice... but!
I will say over all it looks clean enough to not be a rot box. Nice start for a serious body off frame resto.
Way Too much work needed here for 45K. Especially if it was hit hard enough to cause that gross fender misalignment.
One could drive a cement truck through that hood to fender gap! Has to be a 1/2" wide. The core support is likely tweaked along with a twisted fender. No panel test fit before paint for sure.
Lets not discuss the exhaust tips, alternator, spare tire, dash paint and missing stripes et al...
What do you all think? I see a ~$20-25K car... IF the major numbers match, metal is good and frame is straight. You'd need that extra $20K to make it right.
https://www.hemmings.com/classifieds...2/2438457.html
And what's up with all the "floating" digits on the 4-4-2 emblems. They all are out of alignment.. I can't comment on anything except the exterior. When I clicked the link a few moments ago, there are no interior, engine, trunk, etc., photos. Or did I miss this as being your point?
As for the body gaps, WOW!
Anyone here old enough to remember the car commercial bragging about fit and finish, they rolled a BB down the hood/fender body gap. I think it was for Lexus? Maybe Land Rover? Anyway, instead of a BB, for this car they used a bowling ball. 😎
There are a lot of "issues" with this car that bring workmanship into question, but consider the source. The big items have been noted above, A few others are the really crappy Buick steering wheel, the repro heat stove that is just shoved over the exhaust manifold, and the questionable bodywork on the INSIDE of the trunk lid. For $45K you couldn't take the time to find the right screws for the power top switch? And what's with the lamp cord on the alternator wires? I'm not going to disagree with the 50% number.
Check the bottom of the speedometer. It was originally a column shift automatic speedometer. The Park R N D S L letters were polished off. I've scrapped better steering wheels than the one on this car. What as mess.
These dealers are masters of the 20 footer, 50 similar exterior photos, shot from distance - drill down into the details - you see more issues. The keen eye sees them at 20 feet as well. Sadly representative of our superficial world, fortunately knowledgeable people run from BS like this, especially at trumped up prices.
The car is still for sale.
https://www.ebay.com/itm/1977-Oldsmo...0AAOSw-91fiQjU
Wow, I learn something new about every time I visit this site, never noticed this difference before. The little arrows look better and make more sense. Weird that they weren't consistent here. So either that speedo was replaced, or this car was originally a column shift. That makes the mileage 100% suspect too. I can't believe they even took a close-up of that fender gap, holy cow, that knocks $10G off the value right there.
More to the point, and the real reason for this difference: the 67-68 B/C body cars actually used the same gauge pods as the 68-69 A-body cars, and those 67-68 B/C body cars have the PRNDSL indicator in a different window in the dash and not in the gauge pod. The blank speedo face with the crescents actually was the first design used in all 67-68 B/C body cars. It wasn't until the 68 A-body cars were designed that Olds realized they needed to add the shift indicator to the speedo face, which is why the turn signal indicators needed to shrink to make room for the PRNDSL. The rectangular opening just above the steering column notch is the location of the PRNDSL indicator on this 67 Delta dash.
Ok, I understand. I was thinking if the pod was the same minus the cuts, they could commonize since the printing was on the face, but I was incorrect. That shift indicator on that dash reminds me of the 66/67s A bodies, which, for trivial knowledge, all come with a 2 speed auto lens even when covered up by the block off plate (excepting column shift TH400)
