Carb fitting 1970 w30
Old Oct 29, 2020 | 11:40 AM
shiftbyear's Avatar
Was this carb fitting only used on W30 carbs or on all OAI carbs? Thanks
Old Oct 29, 2020 | 12:16 PM
It was used on all 1970 4bbl carbs. The port at the back of the air horn was originally used to source clean air for the hot air choke. This tee fitting was created to provide a second filtered air port for the TCS valve to allow filtered air to flow into the TCS system when the valve was released. This was a last-minute design mod to avoid changes to the carb air horn. The 1971-up carbs had two separate ports.
Vader
Jul 18, 2019 02:06 PM
Olds24
Sep 25, 2018 07:40 AM
SuperNovass
Apr 1, 2012 11:51 AM
Max
Mar 31, 2012 09:48 AM
atkinsom
Jan 20, 2012 10:58 AM
