68 Cutlass 350 differences
Old Oct 9, 2012 | 01:26 PM
boese1978's Avatar
I see this statement, describing the 350's in 68's, here, my Motor's Manual and other places........."standard two-barrel 350 cu in version, four-barrel "Ultra High Compression" 310 hp". So, my query is, is there a physical / build difference in these engines between the 2 and 4bbl's? Correct me if I am wrong but merely putting a 4bbl on instead of a 2bbl does absolutely nothing for compression. Are the extra horses attributable solely to the 4bbl? Assuming what I am writing here is correct, why did they call it a "high compression" engine then? Just for advertising?
Old Oct 9, 2012 | 02:30 PM
hookem horns's Avatar
Compression is due to small dishes on the piston tops.
Old Oct 9, 2012 | 02:33 PM
boese1978's Avatar
yes,
I realize that is part of what determines a compression ratio ...so did the 4 bbl engines come with different pistons?
Old Oct 9, 2012 | 04:13 PM
Octania's Avatar
Yes, in that era, generally speaking, shallow dish pistons were used with the 4-bbl carb. Along with a hotter camshaft, and typically dual exhaust. It's a package.
"low compression" was like 9:1
high compression 10:1, and Ultra High Compression like W31 or Toronado engines approached 10.5:1
Gearhead442
Feb 2, 2020 11:56 AM
98regency
May 15, 2014 02:31 PM
Nor Cal Andy
Mar 20, 2011 04:03 PM
musicars
Aug 19, 2008 11:02 AM
texasred
Jul 31, 2007 11:33 AM
