68 442 Edelbrock intake manifold question
Hi Guys,
Got my new engine back the other day and am adding the parts back on it. I have a performer Edelbrock intake on it. I noticed the hole for the heat/ac valve is larger than stock. The opposite side has the proper diameter.
Any ideas?
Craig
Any ideas?
Craig
71-2 or so and later intakes utilized the 3/4" NPT threads.
No problem, just get the fitting to match.
I have seen as small as 3/8 NPT and many 67-69 intakes are 1/2 NPT.
See the INTAKES thread here for all the gory details.
Thanks guys,
I guess I'll have to find an adapter for it. The problem is where? Nobody carries stuff like this anymore! I feel like Indiana Jones sometimes while restoring it!
My thread seems to be dead (no lookers) If you are interested in my build here is the link!
https://classicoldsmobile.com/forums...ct-begins.html
Craig
Craig
http://www.mcmaster.com/#4429k414/=q2tc2j
Easy as click and buy
Or call or text me and get the proper factory part- assuming heater w/o AC
"bush down" comes from "bushing" which is the typical name for the above part. Get a nice BRASS one for no corrosion problems. Seal it with form-a-gasket or teflon pipe dope. Tape looks tacky.
I think we need a stick on HOW TO SHOP
evidently many folks are not aware of McMaster, Grainger, etc.
Thanks, Octania,
I will shoot for a brass fitting. is there a certain "form a gasket" to get? I'll look for the pipe dope because I agree tape looks like crap!
Yeah, the world got up and changed on me! The last build I did I could still run down to an auto parts store. It takes a lot of work hunting down the parts. I like your idea of a Stick for it!
Thanks,
Craig
Thanks,
Craig
jensenracing77
February 16th, 2024 03:00 PM
pophop
May 13th, 2011 09:57 PM
