'67 Turnpike compression
Was the compression 10.50:1 like the 442, or lower (9.0:1) as in '68-69? If the higher compression, was the only difference the intake and carb on this engine?
Compression on that year was defined by the piston - the deeper the dish, the lower the compression.
You can get a thicker head gasket to lower the compression - custom thickness can even lower it 1-2 points, but can be costly.
I think so, [10.5] but only about 80% sure.
I had a '73 Buick SX w/ a 2bbl. and was told it was the only difference, but that was after they dropped ALL compression ratios.
You'd get better MPG and performance with the Q-Jet, as the primaries are smaller than the 2-bbl., and then you've the secondaries - if you can keep your foot out of it!!
BTW - the rear end ratios were in the mid 2's - great on the hwgy, but not too good for the 'stoplight drags'.
I woud think it is a T/pike Cruiser athough a build sheet would confirm it, obviously.
I don't remember any markings, either inside or out making a designation, athough a rear-end ratio would confirm it a little more.
It was a little known option, except for 'rumrunners'!!
400ci 2bbl had 10.5:1 in 1967
http://www.carnut.com/specs/gen/olds60.html
I have no idea how accurate this sight is
Yo guys this info is in the factory specs at Wild About Cars at http://wildaboutcarsonline.com/membe..._Section_0.pdf
PS, it was the same as the regular 442 @ 10.5:1
Never speculate - use quality reference materials. That's what WAC is all about.
Hope all of you guys join up at WAC - there is a lot of info out there that one can use. When you do, click on the "Latest Uploads" button on the upper left - in your dashboard and you will see a listing of all the new stuff we've uploaded. We add stuff each day and have just topped the 25,000 pages of info mark this week!
www.wildaboutcars.com click on "Register".
cts-v
January 10th, 2009 04:55 PM
Billhillytim
February 21st, 2008 03:32 PM
