66 442 A heads or B heads
Old November 6th, 2014, 02:57 PM
kelly bakies's Avatar
I am working on a 66 442 convertible, 4 speed. The heads that are on the motor are A heads with V010350 stamped in the end of them. Could these be correct if this was a early production car for 66'. If these are not correct are they 442 heads. I have a set of B heads also and thinking about getting them reworked. Not sure what they came from. Is there anything special that needs to be done to them.
Are the A heads worth anything if I sell them?
Thanks for the help,
Kelly
kelly bakies is offline
Old November 6th, 2014, 03:36 PM
66-3X2 442's Avatar
Kelly
Those are not 66 442 heads. They are 65 442 400 heads with that V0 #. A heads didn't come on a 66,only B heads but some 65 442 cars had B heads along with the A heads. 66 442 400 B heads had a V1 # for the engine prefix.
66-3X2 442 is online now
Old November 6th, 2014, 04:03 PM
are B heads a direct bolt on, I read somewhere that the push rod holes may need to be drilled bigger. How would I know if I need to do that.
Also how do you figure out the date stamp of when these were made.
Kelly
Old November 7th, 2014, 04:48 AM
66-3X2 442's Avatar
Kelly
I'm not sure what you're asking about direct bolt on to. All BBO heads interchange. The 65 400 engine is a 45* bank angle & the 66 400 is a 39* bank angle. Since 66 used the B heads and some 65's also did,I do not think the push rod holes need work. Unless the 65 B heads had the push rod holes modified for use on the 45* block,they should work. Maybe somebody who has done this will chime in. The Julian date is on the raised tab above the #2 or #7 exhaust port. It has 2 screw looking heads on each side of the date.
olds4life
December 25th, 2012 12:56 AM
monzaz
June 27th, 2012 01:03 PM
ut442
March 9th, 2012 11:57 AM
gearheads78
November 10th, 2009 09:31 PM
DarkStar
October 21st, 2009 07:35 AM
Quick Reply: 66 442 A heads or B heads
