65 trunk pans
65 trunk pans
Has anyone replaced an entire trunk pan on a 65?
The one thats listed at Parts Place says it needs modification...
https://www.thepartsplaceinc.com/pro...dy-panel/53343
It looks like a skylark pan.
https://www.opgi.com/sheet-metal-bod...saAnsREALw_wcB
Here's one for Tempest
https://www.partsgeek.com/gbproducts...gaAugMEALw_wcB
And one for a chevelle
https://www.ss396.com/chevelle/RTF-1...oaApDJEALw_wcB
****Are they all the same except the trailing edge?
Can you use any of these?
B is the area that is different. The straight part of the frame rail on each side of the gas tank is 3" - 3 1/2" inches longer on the buick, pontiac and olds I want to say 3 1/2" but I would have to check to be sure. The longer frame is used on 64-67 chevelle wagons though.
This is an old thread, but you might ask Rob which one he used.
64 "post" granny car 915 trim code - ClassicOldsmobile.com
If anyone cares...I ordered the only one in stock I could find through OPGI.
Shipping was ridiculous.
I ordered the skylark pan and it's beautiful. All the braces, cage nuts, decent gauge metal that's e-coated.
I can't wait to get this in.
I'm wondering if I can slide it in from the rear as the quarter panels are so much narrower at the bottom?
thanks
duane
If the car does not need quarters, your best bet is to atleast try to get it in through the back. If you are replacing the quarters or even just repairing the lower section, put it in from underneath.
The wheel houses are in good shape...and so are the quarters to my knowledge.
I'm planning on cutting it out and removing spot welds on the red dotted line.
Hopefully that will allow me to slide it in from the rear and remain on the underside of the bracing like factory.
And Duane...I'll start a new thread when I start. Might be as soon as this weekend.
nice 64 dog dish
