'65 Starfire info.
'65 Starfire info.
I recently purchased a '65 Starfire convertible. All of the info. Ive found on this car is that it came with a 425/370 hp 4bbl. My motor has a casting #386525A but has a 2bbl carb and intake. The intake number is 384438. Also the number stamped on the head is M099172. Did they offer a 2bbl. Configuration for the Starfire or am I to believe this is not the original motor? Anything else I should be looking for? If this is a different 425, if I installed a 4bbl. Intake and carb, would the original Starfire specs. Be achieved or are there other differences to consider. Any expertise are appreciated.
You are correct, this is not the original engine. Starfires only came with a 4bbl motor that year. The "M" prefix in the engine unit number on the head indicates that this was a 2bbl motor from the factory. Unfortunately, it could be either a 10.25:1 motor or a 9.0:1 motor.
Thanks for taking the time to answer. Is there anyway I could identify if it was the high compression or low compression version?
There is a local guy who is selling a 65 4bbl intake for a 425. If I chose to convert this to a 4bbl set up, would the carb. Selection be different depending on high compression or low compression?
viper771
August 31st, 2011 07:20 PM
Kaline
Brakes/Hydraulic Systems
August 5th, 2010 06:46 PM
sx455raidercelticfan
August 1st, 2010 08:03 PM
