'65 Starfire info.
Old Jan 29, 2017 | 10:51 AM
Oldsoul's Avatar
'65 Starfire info.
I recently purchased a '65 Starfire convertible. All of the info. Ive found on this car is that it came with a 425/370 hp 4bbl. My motor has a casting #386525A but has a 2bbl carb and intake. The intake number is 384438. Also the number stamped on the head is M099172. Did they offer a 2bbl. Configuration for the Starfire or am I to believe this is not the original motor? Anything else I should be looking for? If this is a different 425, if I installed a 4bbl. Intake and carb, would the original Starfire specs. Be achieved or are there other differences to consider. Any expertise are appreciated.
Old Jan 29, 2017 | 11:44 AM
You are correct, this is not the original engine. Starfires only came with a 4bbl motor that year. The "M" prefix in the engine unit number on the head indicates that this was a 2bbl motor from the factory. Unfortunately, it could be either a 10.25:1 motor or a 9.0:1 motor.
Old Jan 29, 2017 | 12:21 PM
Oldsoul's Avatar
Thanks for taking the time to answer. Is there anyway I could identify if it was the high compression or low compression version?
There is a local guy who is selling a 65 4bbl intake for a 425. If I chose to convert this to a 4bbl set up, would the carb. Selection be different depending on high compression or low compression?
Old Jan 29, 2017 | 01:08 PM
lemoldsnut's Avatar
The intake manifold is rather unique. It is 65 only. In 66 Olds went to quardrajet carbs so they are different. I have a 65 intake as well.
Old Jan 29, 2017 | 03:30 PM
The question is, do you want a correct one-year-only 1965 intake and the 4GC carb or is a newer intake and carb acceptable to you? The 65 intake only fits a square bore carb, so you can use the 4GC or a Holley or Edelbrock. The 4GC has a smaller diameter air horn and requires the matching air cleaner. A Holley or E-brock has the standard 5 1/8" air horn, making air cleaner availability much easier. Alternately, get a later intake or aftermarket and use a Qjet.
Old Jan 29, 2017 | 10:34 PM
Ancient Iron's Avatar
Starfire engine also had it's own camshaft .Different grind than an 88 or 98 motor
Kaline
Brakes/Hydraulic Systems
Mar 31, 2025 06:49 PM
viper771
Aug 31, 2011 07:20 PM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
viper771
May 31, 2010 12:40 PM
daves62
Dec 6, 2008 05:44 PM
