65 Delta 88 ignition lock
I need some help finding the correct ignition lock for a 65 Delta 88.
It seems nowadays when you look for parts online everything fits your car. I'm surprised air bags don't show.
Anyways, I ordered an AC Delco that said it fit my car. It doesn't.
The GM part number on the box says 19162133
It doesn't fit all the way in the ignition switch nor does it lock into place.
Which ignition lock should I be looking for? The internet is seriously sometimes like the cereal isle now. So much crap with no info.
I even searched on here and didn't end up with anything.
"Switch" 1116661
"Cyl. (less springs, tumblers, & ret.)" 1468116
The 1966 parts book shows two different numbers, but not the one you gave.
Sometime part numbers have changed through the years on the same (replacement) part.
Have you tried page 23 of: http://www.fusick.com/catfile/Catalog%2023BC.pdf
If you can't find the part you need, and originality doesn't matter, you may be able to substitute a generic switch & cylinder combo.
Well I figured it out. Seems 65 had the octagon key. The cylinder has a small offset post on the back to turn the ignition switch. 66 they switched to the more standard larger square gm keys. So It turns out when I ordered an ignition switch and lock online, I got a 66 ignition switch and a 65 lock. The 66 lock has a large flat blade type thing on the back to turn the ignition switch. I like the larger keys so I just ordered a 66 lock.
Probably will end up getting new door locks too.
Does anyone know if the door lock cylinders can be rekeyed to match the new ignition lock?
goldie442
August 21st, 2015 11:01 AM
