64 starfire wiper motor
Old Jun 8, 2017 | 12:36 PM
Hillbilllystarfire's Avatar
When I got this 64 olds the wipers didn't work. I checked the connection and there is power going to the motor. I took the motor out and banged it around, and tested it by plugging it back in. When I turned **** to low I heard s click or something then another one when I turned to high. I turned the **** off then back on again, I heard a pop then noticed the motor was turning. I turned to high and it went faster. I turned it off the back on again and it worked again. I unplugged it because I had to wait on a retainer clip. I left it setting on the workbench for a day. After a day of two the retainer clip came so I plugged the motor up one more time to check it before putting everything back together, and now nothing, just after I plugged it in it touched the arm that goes to the cruise control and there was a spark. After that there was nothing I couldn't get it to work, but I know it's getting power at the connection.
Old Jun 8, 2017 | 01:34 PM
Oldsfan's Avatar
I just went through a similar problem on my '62. There is a relay in there that pulls on some linkage that allows the motor to turn on. Mine was gummed up with old grease. I had to disassemble it and clean it good and put some new grease on it. Or maybe the relay is bad. I'd look at that linkage first.
oldspackrat
Mar 12, 2015 06:34 PM
BaileyJD1
May 10, 2008 03:33 AM
bingo
Apr 13, 2007 06:52 AM
JoshF85
Oct 17, 2005 08:41 PM
zeeone
Jul 19, 2003 10:08 AM
