54 Super 88 power steering question
I guess I didn't take enough pictures as I dismantled things. There is a guide bracket that the PS hoses run through on the driver side of the engine. I don't recall where that bracket bolts on. Can anyone shed some light?
Many thanks!
Many thanks!
I have this photo, of the entire system removed from a '55 S-88...steering box to pump removed as an assembly - don't see / recall this bracket. However, I'll look tonight at my other PS car ans see what I can see..
Back to the top! 54 PS question...
Thanks!
There is a special head bolt with a threaded hole to accept a ±1/2" hex bolt, attaching bracket to head bolt which apparently is missing. Should be in position noted by my orange arrow in your pic:
CW
CW
Aaaah! I wondered if maybe that was the case. My engine builder must not have put that specialized bolt back in. It may be in with all the spare parts. (We made one engine out of two) The next question would be is it safe to replace that single bolt without causing other problems?
Is that a 53 engine you have pictured?
Thanks for the info!
nicks1966
January 12th, 2014 01:46 PM
cluelesscutlass
January 3rd, 2012 06:18 AM
