54 Super 88 power steering question
Old May 6, 2012 | 09:27 PM
Rocket331's Avatar
I guess I didn't take enough pictures as I dismantled things. There is a guide bracket that the PS hoses run through on the driver side of the engine. I don't recall where that bracket bolts on. Can anyone shed some light?
Many thanks!
Old May 7, 2012 | 04:58 AM
Olds Dad's Avatar
Collector of Stray 55's
I have this photo, of the entire system removed from a '55 S-88...steering box to pump removed as an assembly - don't see / recall this bracket. However, I'll look tonight at my other PS car ans see what I can see..
Old Jan 23, 2013 | 05:02 PM
Rocket331's Avatar
Back to the top! 54 PS question...
Many thanks!
I still haven't figured out where this bracket attaches. (see arrow) It's possible the bracket is slid on the hoses in the wrong direction. If you have a 54 with power steering, please take a look (and maybe a picture or two) and let me know where it attaches.
Thanks!
Old Jan 23, 2013 | 07:51 PM
coldwar's Avatar
There is a special head bolt with a threaded hole to accept a ±1/2" hex bolt, attaching bracket to head bolt which apparently is missing. Should be in position noted by my orange arrow in your pic:
CW
Old Jan 23, 2013 | 08:26 PM
Rocket331's Avatar
Aaaah! I wondered if maybe that was the case. My engine builder must not have put that specialized bolt back in. It may be in with all the spare parts. (We made one engine out of two) The next question would be is it safe to replace that single bolt without causing other problems?
Is that a 53 engine you have pictured?
Thanks for the info!
Old Jan 27, 2013 | 06:38 AM
coldwar's Avatar
Pic is of a 1952. Some risk associated with changing out a head bolt but I never had trouble after doing only on stock engines. CW
nicks1966
Jan 12, 2014 01:46 PM
Raydermiike
Sep 19, 2013 07:50 PM
JCMC64
May 9, 2013 04:43 PM
cluelesscutlass
Jan 3, 2012 06:18 AM
russell-t
May 1, 2011 08:57 AM
