455 "X" heads
455 "X" heads
Has anyone every heard of Oldsmobile heads with X in the place of the C,D,E,F etc. I hate to admit it but I never have. I know of a guy selling what he said were 455 Oldsmobile heads. When I asked him what letter is on the heads (I sent him a diagram to show him where to look) he said it's an "X". Anyone know what these could be and from what year if they even exist?
I once had a pair of strange OE heads. Back in the 90's I found a set at an engine rebuilder down in McAllen Texas - they were CA heads, but both letters were small - like the "A" in Ga heads, and both letters were in the middle of the pad where the big letter would normally go. I wish I had kept that set - if for nothing else interesting conversation pieces.
Yep. Check out this ebay auction. The Pontiac heads have an X cast into the same location as your photo. John
http://www.ebay.com/itm/1973-1974-PO...c68a66&vxp=mtr
I Have an Olds 455 engine and it does have X heads I don't know what this engine came out of originally but the block number/casting # 396021F should be out of a 442 1968-72 and it now sits in my 65 442 Convertible.
Olds X heads
This is a big block olds engine and I am pretty sure that X is stamped right on the heads I am going to check it further to see if there are other numbers stamped on the heads. It is clearly the correct casting code for a 1968-72 F block engine (did Pontiac have the same casting code on it's 455 engine)?
I'm 110% sure it is NOT an "X". Casting number on the block is the same for all 1968-1976 Olds 455s. Pontiac motors are COMPLETELY different designs with completely different castings. Nothing interchanges. Once again, photos will solve this question in very short order.
I guess I figured out how to attach the photos, I hope they put the debate to bed 110%. I was reading other threads and many mention a Pontiac 455 engine which I know is a totally different animal! Also mention of a 307? I can't see mistaking a 307 for a 455 BB it is totally obvious that it's a BB just by looking at it!
Your head does indeed have an X on it but not in the position that this thread is talking about. Oldsmobile heads either have a number or letter on the far left outer corner. The heads in your picture have a J in that spot.
ahh, ok I see it now, (left side of the head)? didn't see it before just saw the X jumping out at me and figured that, that was the casting on the head. Not trying to be argumentative just honestly thought that the X was the casting. I found out now what I have. Can anyone tell me about the J head? Is that a common head or anything special about it to know? Thanks, Vinny
I consider them common. J head castings were installed on 1973-1976 455 engines. The heads are not considered the best for performance due to their design to meet emission requirements of their day.
I don't see an option to add a photo to "profile". But..If you want to add a photo for your avatar under your screen name, go to "user cp" and find "settings and options". There you will see "edit avatar", follow the instructions and understand the photo will probably need to be resized to meet the requirements. Good Luck and happy motoring.
#31
Thanks for the info! My block casting # 396021F is listed on BRO442 as 455ci 68-72 so I guess the heads must have been swapped out at some point or (could be a late 72 build)?. motor runs great so I am not going to do any work to it until it fails then I will think about my options. I'm just cleaning it up and painting it bronze so it looks correct in my 1965 442 convertible.
#32
Thats what I meant, I thought that was considered a profile pic (like FB) Thanks for the help and info! I just purchased the 65 442 and going to make a nice driver for now and then see where it goes from there...you know how these projects just keep growing and growing!
#36
I had a set of those CA heads and I read somewhere or somebody told me they had hardened seats in them. It may be in the Joe Mondello spec book where I saw it.
#37
Does anyone know what the correct bulb size is for the rear quarter (arm rest) interior panel lights for a 1965 442 convertible?
#38
#39
Hi Joe I'm learning as I go along and was also hoping that my block was an earlier year with a better set of heads etc. but as I said in my earlier post the engine actually runs really well and I am not building a race car so it's fine for now. Thanks again for the info!
#40
Sorry I mentioned the 307 story earlier, it's just something I ran across in the past.
I know other folks must be wondering too, what is the X stamped on those heads? I've seen plenty of J heads in the past and I don't recall an X stamped there (maybe I'm just forgetting). Might it indicate a place of manufacture or an OE replacement part?
MDchanic
Wheels and Tires
22
August 4th, 2011 11:23 AM
81 regency
April 21st, 2011 07:18 PM
