455 radiator
Old Jan 18, 2014 | 06:59 AM
crank shaft's Avatar
455 radiator
IM getting ready to do the 350 to 455 engine swap. I have a 2 core radiator in the car right now and probable should upgrade. Will a 4 core fit in the 2 cores place or will I have to swap out the core support?
Mike
Old Jan 18, 2014 | 07:12 AM
tru-blue 442's Avatar
Old School Olds
What model are you working on?
Old Jan 18, 2014 | 07:16 AM
1970 Olds cutlass supreme.
Old Jan 18, 2014 | 07:27 AM
Old School Olds
That model stock should have came with a 3 core.
All Cutlassas in and around that year w/455's had
4 cores. At least of what I have seen, if it had heavy
duty cooling, w/air. We just don't see a lot of cars down
here in Texas without air from back in the day. I have heard
of guys speading the saddles to get them to fit, but I believe
they are spot welded to the core support at the bottom and also
the cap on top as well.
Old Jan 18, 2014 | 07:31 AM
It looks like I have a 2 core in it now, Car does have AC, I looked in the filler neck and counted 2 row of cores. Some one probably swapped it out. Do you know of an aftermarket that would be a direct bolt in?
Old Jan 18, 2014 | 07:36 AM
Old School Olds
Someone will chime in with that info.
I think John, 2blu442 may have some extras
that would work for you. You also may try
Scott, oldspackrat. These guys would have
oem radiators.
Old Jan 18, 2014 | 07:45 AM
Ok Cool! Thanks for your help!
Old Jan 18, 2014 | 07:49 AM
Old School Olds
No problem. If any of my info is
wrong, we will hear about it...
Old Jan 18, 2014 | 07:53 AM
lol
Alex72cutty
Apr 21, 2015 10:30 AM
59Olds98
Aug 14, 2013 09:38 AM
g77rvd
May 13, 2011 11:29 AM
Airyonn
May 7, 2010 10:05 PM
cfair
May 31, 2009 09:18 AM
