455 in a 92 Olds Station Wagon?
I have been posting at a station wagon site for the past week or so. I have considered purchasing a 92 Oldsmobile Custom Cruiser. It currently has a Chevy 350 and 4L60 transmission with an 8.5" GM corporate rear end. I was wondering if you guys think a 455 would fit into this vehicle? If so, do you have any pointers or suggestions for shoe horning it in? I spoke with the fellas at the station wagon site and they aren't too knowledgable about this swap.
I have already done some reasearch and I found this adapter plate to bolt up the engine to the transmission:
http://www.jegs.com/webapp/wcs/store...10002_74970_-1
I also know that the 4L60 would have to be built to withstand the torque of a 455. I am wondering how a 455 would bolt to the crossmember since the crossmember is designed for Chevy motor mounts...
I am also wondering if the 8.5" rear end would have to be built to withstand the torque of the 455.
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Your biggest problem will be emissions. If you must have the car emissions tested where you live, NO Olds motor will pass since none was certified for the 1992 EPA requirements.
Yeah, luckily Oklahoma doesn't do tail pipe tests or safety inspections. If I moved to Texas or Missouri though, I would be up the creek without a paddle. ![Smile](https://classicoldsmobile.com/forums/images/smilies/smile.gif)
Thanks for the info Joe. I knew that the previous generation station wagons used the 307. I just wasn't sure how similar the newer wagons were to the older generation.
If I could get that 455 in there, it would be an awsome car!
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
See if OK has any kind of Classic or Antique car status that is emissions exempt.
Pennsylvania is the 2nd most strict state in the country for emissions, next to California of course. But it's only in certian counties, like Philadelphia and the counties around it, and Alleganny (sp) county (Pitsburg) where the bulk of the population is.
A classic car in PA has to be at least 15 years old, and the only thing is the car cannot be used for daily transportation, and Antique cars have to be 25 years old and can only be used from sunup to sundown. Both classes are emissions exempt.
If I were to do my Bravada project. I would have to buy a '93
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
Yeah, I should probably double check the laws in OK. I know it is similar in MO. IF your car is over 25 years old you can register it as an historic vehicle and don't have to do tail pipe tests or safety inspections.
Missouri
As long as you don't move to St. Louis, and your engine has the correct original "Emissions" equipment in place, then you should be fine for a MO safety inspection. St. Louis does some emissions testing, but the rest of the state (AFAIK) does not. Why would anyone want to live in St. Louis anyway?
I know what you all mean about the emissions. Actually, I don't know if the OCC would be a good investment for me right now. I think I am going to go ahead and finish my engine and then see what happens. If I put $2500 into a car then I won't be able to finish my engine as fast.
True, but...
Virtually all localities that have emissions inspection requirements have adopted the California philosophy on engine swaps: You can usually swap in a cleaner engine but not a dirtier one. Since there were no Olds 455s (or any Olds V8s) that were certified to comply with 1992 emissions, you cannot legally install one.
Depends
Depends on where you take it for the "visual" inspection. How many mechanics are going to go to the trouble of decoding a VIN to verify an engine? Especially if it's your friendly "local" shop that does a lot of work for you...
I know for a fact that in NJ you cannot swap in a motor that is older than the car.
So if my 2000 Alero blew a motor and I dropped in a 99 motor, it would considered illegal![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
Whne I got my Delta inspected the paperwork said "5.7 Liter 350 engine" They never came with a 350 in '85
reddevil1311
April 10th, 2012 05:37 AM
