455 with a 350 turbo
Old Feb 19, 2013 | 01:41 PM
blackngold442's Avatar
Hey guys need your opinion I have a 1972 cutlass I'm going to put a 455 in it and I have a turbo 400 and a 350 turbo but the 400 is a long shaft and I got to do some mods to make it work. The turbo 350 would bolt rite in with no problem but wanted to no would it hold up ok against the 455 with all that torque ?? Not racing the car it's a 71 455 with g heads!
Old Feb 19, 2013 | 01:49 PM
I'd be willing to guess the T350 will work just fine. Just don't beat it like a rented mule.
Old Feb 19, 2013 | 02:06 PM
47 Convertible's Avatar
350 transmission will bolt up to 455 but why would you do that? If you are going to the trouble to install a 455 why not put the correct transmission behind it? I say do the job right once instead of doing it over later and having the car out of commission twice.
Old Feb 20, 2013 | 08:28 AM
455man's Avatar
I've blown TH400's with a mildly built daily driver 455. If you have the TH350 built right it should last as long as you don't torture it.
Old Feb 20, 2013 | 09:52 AM
pogo69's Avatar
morgan
I had a 72 455 with the 350 trans and it just didn't have the get up and go
Old Feb 20, 2013 | 10:52 AM
halfmoontrail's Avatar
Acceleration shouldn't have been a factor with the TH350, that's more related to rear end gearing.
Old Feb 20, 2013 | 10:58 AM
droptopron's Avatar
delete
If you have both on hand run the 350 for now & see if there is a problem. if you blow it swap to the 400. There are plenty of guys running 350's behind big blocks.
Old Feb 20, 2013 | 12:28 PM
jfb's Avatar
jfb
hey buddie i run a serious 455 in front of a bullet proof 350 trans and have had 0 problems and i mean serious power plus a overdrive gvod to be exact. I picked up this completely bullet proof 350 trans for a song and dance,My friend who does trannys for a living and his dad for 35 years said that a 350 trans can really hold up very well even stock Time proved this, Detroit really overbuilt these cars for real abuse then like class racing. I say we should reap the benefits and let it roll.
Old Feb 20, 2013 | 12:33 PM
oldsmobiledave's Avatar
Curious
Ever wonder why GM never used the T350 behind the 455?
Old Feb 20, 2013 | 12:37 PM
vistacruiser67's Avatar
I have a stock 71 G head 455 backed with a stock 72 350 TH. Neither have ever been rebuilt. I put 30k miles on this combination with no problems. Motor has about 180k plus , trans has about 170k. 30k miles of hot rodding with no problems whatsoever. Tired engine and tired trans but no problems. Some say you gain a little power with the lighter trans and smaller torque converter.
Old Feb 20, 2013 | 07:47 PM
tm70olds's Avatar
I have a 350 behind my 455.When I first put it in it was a little slow at shifting so I took it out and had it rebuild and a shift kit put in it.That was 11 years ago. The car pretty much just races mabe a show every other year.It has run as fast as high 11s but runs consistant 12.0s for that index class and bracket. So you shouldnt have a problem unless the 350 is tired.
Old Mar 1, 2013 | 05:21 AM
John (Jack Troxell) switched to a 350 turbo in this 455 powered 71 Vista Cruiser in the early 70s in Junior Stock competition. Troxell had great success running 12 second records at the time. The wagon was sold to Dick Griffin and named Vista Bruiser and later raced by Paul Mayo for Lubik Olds and then repainted with a rainbow Chesrown Olds scheme. It is unknown if the 350 trans was left in tact for the succeeding racers. The Vista was one off car ordered from the factory with a ram air hood to get the option on the books so it could legally be drag raced in its class. All this done with the help of Oldsmobile's Dale Smith. It paved the way for a rumored 3 Vista Cruisers in 1972 ordered with the W-30 option one of which(brown in color) is owned by George Berejik. The Troxell Vista pictured still exist today. Anyway another example of a 350 trans running hard behind a 455.
Old Apr 29, 2026 | 02:41 PM
chops442's Avatar
Hi John
matviar
Feb 26, 2012 11:05 AM
80_cutlass
Mar 17, 2011 06:03 PM
Liegekiller
15
Jun 27, 2009 07:58 PM
Liegekiller
May 30, 2009 05:31 PM
