40yr old car is falling apart !
more fun ..... I beleive the ignition switch is going bad , when I turn the key the steering wheel seems to unlock normal , but there is a very noticeable hesitation and " click " noise in the igniton before the ignition is turned far enough to start the car ... and like before the hot indicator dummy light on the dash lights up and then keeps flashing on and off , even with the engine cold ... i would not think the two are related .The light is working properly now , but the ignition still feels messed up.... I'm afraid the alternator is on the way out to ( a diode perhaps? ) it still starts the car fine , but I get the gen light to flash on and off everytime I shut heat off or every once in a while when I take my foot off of the brake.... I beleive the alt is about 10yrs old.
On these old cars you can expect to change out the key ignition switch, so its not uncommon as is the altenator.
If this is your daily driver, you need to consider doing this soon as not to leave you stranded.
It a $12-$14 part. If you've never done it, you're gonna need a little help. It only takes an hour or much less if you've done it before. The job will require two special tools that you can probably rent at the auto parts store where you get the switch.
The tools are:
Steering wheel puller
Lock plate removal tool
Its also very handy and allmost required to have the Factory Service Manual to know how to do this Good luck.
About the Altenator, just remove yours and exchange it for a new one and be done with it. It might cost 50 bucks or so, you don't need no fancy 100 amp unit.
The tools are:
If you've got a bad gear or other components, it should be easy to find them.
I'll trade you for a 12 year old car that's falling apart!
Do you mean the key in the column of the actual ignition switch (electric) lower on the column? The one on the column is an easy job tou do yourself and should be readily available at any parts store. Only difference being if you have tilt, I believe.
As far as I know, the non-tilt internal column parts are all the same for pretty much all GMs through the late '70s / early '80s.
The tools are:
The tools are:
Alternator? Easy - take it out and get it load tested - Autozone, O'reilly's, etc. They do it for free. If it comes back shot, you have your choice to rebuild it yourself or you can buy a new one.
O'reilly sells rebuilt for 45 + 15 core
Rock Auto is a great deal: AC Delco - 63 amp 53.00 including 5.99 core charge
Here's a link to help you with your steering column diagnosis: http://wildaboutcarsonline.com/membe...Section_9C.pdf
Bryon, do you have the CSM for 72? That will help you change out the keylock.
how hard of a repair is it to do , if that is the problem ? ive taken electric motors apart before and dealt with the brushes and what not so maybe this would be the way to go.
Jim
If you have the factory service manual, the instructions are in there.
Here is where I repair the alt on my '86 Cutlass. It is a newer type, but the concept and many of the parts are the same. The new one has the internal regulator (which I had to replace in mine).
https://classicoldsmobile.com/forums...lternator.html
I replaced the brushes in the alt of my Ford with no trouble. Took an hour, just taking my time. Worked fine after. I can still say it has the original alt, too!
Bryan -
The alternator is easy to take apart and repair, and you can change the brushes, regulator, diodes, and bearings for much less than paying for a rebuilt unit.
If you want to take your column apart, you don't need that compressor tool - you can sit in the driver's seat and press the plate down with a few fingers while picking out the clip with a pair of small screwdrivers - it's a bit tricky to put it back together, but you can do it if you're patient. I've never used one of those tools. If you really want one, they're about $14 at the parts store.
Before you remove the lock cylinder from the column, make sure it's what causing the problem. It sounds like the ignition switch (electrical switch on top of column) may be causing the binding. Un-bolt it from column and work the key and see if it is still binding. Most of the time the electric switch is the problem.
Jim
Jim
Since you can do motors, an alt is not too much more involved. You can do it!
Bryan -
ok .... now everything seems back to normal , but now I have a screaching sound coming from the front of the motor mainly when the motor is cold and not under load..... im thinking waterpump bearing or the alternator bearing is going !!!!
Well a few things come to mind.
1. If your water pump wasn't screeching before, replacing your alt won't make it fail either.
2. I'm leaning more toward your belts need tightening. When you loosened off the belts to get your alt off/on you might not have done them back up enough? I would check that first before jumping into a water pump.....
3. When you rebuilt the alt did you change the bushings? Or did you get some crud in there?
Did you know that you can take a long screwdriver and roll your hand around the handle end, making a cup with your hand. Hold your cupped hand to your ear and use the screwdriver blade to probe like a stethoscope and listen for noise. It could help isolate the noise to the pump or alternator.
Or you could break down and spring a few bucks for a store-bought one. There work pretty good.
Bryon, (this sounds so like a line from "Hunt for Red October") you've gone and broke your car -again?
Bryon,
Don't sweat bullets. You're a really level headed guy who's given me some good advice over the past year too. I'd start with the belts.
Even if it's the alt or water pump those aren't really big ticket items to replace. Just takes the better part of the morning to git 'r done. I'm totally confident you will find the answer. As you know, don't take everything apart all at once. Use the process of isolating one thing at a time. BTW, cool tip on the screwdriver Highwayman! Might help to stuff some cotton in the other ear so you get more direct sound through the driver?
I started car at lunch time here at work , and the screaching sound has a little grind to it too making me think its a bearing again instead of a belt... its not ruled out though.
Water pumps? Around 30 - 40 bucks at OR, 25-30 at R.A.
Now that you're at this stage, you might as well pull the engine and do everything.... Aren't fiends like us nice to have around?? (Yeah, it's spelled right)
#31
Bryon, if you have to change the water pump, you're more than half way to replacing the timing chain! Timing chains are cheap too! (less than 20.00 from R.A or O'reillys) Can't you just feel the love???
#32
Yeah, but....
I have read (can't recall whether a thread here or Bill Trovato's book) that the really cheap ones can be something like 7° off .
I don't have enough experience to be able to verify this myself, but the advice is to use a "better" set at a higher price, and degree it to be sure it's good.
I suppose you could use a cheap one and degree that, but you may be running back and forth to the store returning bad units for a while.
#33
Yeah, but....
#34
Ok, I'm not arguing. Here's the thing. I just checked RA, O'Reillys and Autozone. The 'most expensive' chain any of them sell is 26.00 (AZ). Even jegs is only around 27.00 for just the chain. What is the criteria to determine 'a cheap one?". I need to know this because I also am looking at an engine rebuild. Prolly will be part of the kit, but how do you tell if the chain is 'substandard'? They all have 48 links. What brand is better? Also, if you replace the chain, is it recommeded to change the timing gears too? I thought the gears were reusable unless they have damage to the teeth.
#35
Allan, as long as you have the chain off, you're more than half way to replacing the gears! Those gears can't cost that much. Might as well while you're there......
#36
All together, it's probably about $60-100. I think there are sets of chain and gears for about $20 total. Don't buy those (or, if you do, be SURE to check them with a dial indicator!).
#37
That makes sense. Most of the gear/chain sets I looked at were around 70.00. To be honest, I'd be scared of a set of gears and timing chain that cost 20.00. You get what you pay for (mostly). Thx Eric
#39
Diagnosis of Bearing Noise
I figured I would just remove each belt and see where the noise is coming from .... Pic #1 .... I started with the alt , and that was not it , so now I was going to loosen the power steering adj up so I can remove that belt to see if its the water pump bearing .... Question # 1 Pic # 2 , Which bolt loosens the adjustment on the PS ? the one circle ? It looks like I may be able to sneak a adjustable wrench in there but it will be tight.
