350 swap in a 77 cutlass supreme
I have a 77 cutlass supreme with a 350/th350 engine needs rebuild and im doing my reaserch and seeing my options. How hard will it be to swap for a 455 I have a chance to grab a rebuilt one for 1300 w/ no heads. Will I be able to just drop the 455 in with not that much to change?
So it will be a drop in what will I have to change? Will I haelve to change out my radiator.. the tranny. I might just get it rebuilt for the abbuse a bbo. Will let out. So what will I need to change
Heavier duty radiator. Beefed TH350 or swap to TH400. Intake and exhaust manifolds for the BBO. Correctly calibrated carb. High torque starter is preferred but not mandatory. That's it.
hey Ray, I'm local and I have a set of 455 olds exhaust manifolds just laying around. If you need them let me know. I could also give you a little advice on your swap as I've done several in the past few years and am currently doing a 350 swap to 455 in my convertible. Well, done!!!!
oldrelics
Non-Olds Engines
June 12th, 2014 07:09 PM
'69CutlassVert'
August 25th, 2011 07:19 AM
olds70supreme
August 1st, 2011 05:22 PM
