350 swap in a 77 cutlass supreme
Old Jun 15, 2011 | 01:14 AM
rayfrausto's Avatar
I have a 77 cutlass supreme with a 350/th350 engine needs rebuild and im doing my reaserch and seeing my options. How hard will it be to swap for a 455 I have a chance to grab a rebuilt one for 1300 w/ no heads. Will I be able to just drop the 455 in with not that much to change?
Old Jun 15, 2011 | 07:03 AM
The 1973-76 cars had the 455 as an option, so it bolts into your 77 as well. You'll need the correct BBO exhaust manifolds. Use the water pump, accessory brackets, and pulleys from the 350. The 350 distributor will also work with the 455, as will the valve covers.
Old Jun 15, 2011 | 09:09 AM
rayfrausto's Avatar
So it will be a drop in what will I have to change? Will I haelve to change out my radiator.. the tranny. I might just get it rebuilt for the abbuse a bbo. Will let out. So what will I need to change
Old Jun 15, 2011 | 09:31 AM
Heavier duty radiator. Beefed TH350 or swap to TH400. Intake and exhaust manifolds for the BBO. Correctly calibrated carb. High torque starter is preferred but not mandatory. That's it.
Old Jun 15, 2011 | 10:57 AM
rayfrausto's Avatar
Sounds good enough wat about I read here I might have to do something with my driveshaft
Old Jun 16, 2011 | 06:26 AM
Only if you change to a TH400.
Old Jun 19, 2011 | 09:45 AM
projectheaven's Avatar
hey Ray, I'm local and I have a set of 455 olds exhaust manifolds just laying around. If you need them let me know. I could also give you a little advice on your swap as I've done several in the past few years and am currently doing a 350 swap to 455 in my convertible. Well, done!!!!
falconsfan
May 14, 2015 05:47 AM
undercar1
Aug 23, 2014 02:43 PM
oldrelics
Non-Olds Engines
Jun 12, 2014 07:09 PM
'69CutlassVert'
Aug 25, 2011 07:19 AM
olds70supreme
Aug 1, 2011 05:22 PM
