350 to 455 engine swap
Old Sep 30, 2010 | 06:09 PM
goobsmobile's Avatar
Hello to all you OLDS lovers out there.I just put a 455 olds in a 71 supreme,I am having a problem lining up the power steering,I moved the alternator to passenger side of car that works fine,but the alternator is lining up with the pulley that the powersteering pump is supposed to run off of. Can anybody help me?The car had a/c I eliminated it.
Old Oct 1, 2010 | 07:06 PM
64Rocket's Avatar
Your best bet was to use the water pump and all the pulleys from the 350.
Gene
Old Oct 2, 2010 | 08:12 AM
Don L/442's Avatar
Do you have the spacers in place for the power steering brackets?
Front spacer is approx. 3/4" and block side spacer is 1/2"
Old Oct 3, 2010 | 04:30 PM
Start from the beginning. Which water pump did you use and which pulleys are you trying to use. The A/C pump is longer than the non-A/C pump, and using non-A/C brackets will cause a problem unless the pump, pulleys, and brackets are used as a matched set.
OldsCool9
Jul 9, 2013 02:00 PM
71RadioflyerVista
Mar 14, 2012 10:08 AM
oldsmobum
Jan 14, 2011 10:10 PM
dharlett
Sep 23, 2009 03:30 PM
Olds71suprema
May 10, 2008 04:57 PM
