215 operating temp and TV linkage
Hi I had a couple quick questions. What is the normal operating temp for a olds 215. And this motor had an aftermarket edelbrock 4 barrel. Is the TV linkage a push or pull on the factory setup. Meaning is it mounted on top of the Pivot with the throttle rod or is down below so that it would travel in the opposite direction. Thanks for any info.
Engine temp should be about the same as any older engine. A good cooling system should keep it under 200 without much trouble. I have found that MOST of the radiators in these cars need re cored with a quality core and not a China made one.
Also, understand that the cooling system on these cars is not designed with a recovery tank and thus you aren't supposed to fill the radiator right up to the very top. You need to leave expansion space. The factory radiator will have a fill line embossed on the tank. Overfilling will cause the car to puke coolant when you shut it down.
First, the RH5 trans doesn't have a "cable", it has a rod. Second, adjustment isn't done like it is on the later GM OD transmissions. The CSM calls for a specific gauge tool that no longer exists. The ONLY other way to adjust the TV rod is trial and error. Adjust it, drive it, see how it works, adjust is some more. Don't be stupid about how you drive it, but there's no other way on these cars than to road test it.
Emreozd
February 19th, 2012 07:27 AM
