1972 Oldsmobile Toronado 455 with power steering and AC, main Drive Belt tensioner lo
Trying to replace some belts. Looking for tensioner to remove the Crankshaft and Water Pump belts. Any help would be great.
A year-specific FACTORY chassis service manual is the single best investment you will ever make for your car, especially if you're unfamiliar with the car.
I strongly recommend getting an original print copy. Reprints and CD copies often lose critical details esp in wiring diagrams.
And yes, the shop book shows how belt and accessory drives are laid out and how to properly tension the belts. Oldsmobile even had a belt tension gauge with specs.
https://classicoldsmobile.com/forums...44/#post432836
