1972 Cutlass Supreme Alternator
I am needing to replace the alternator in my 72 CS. It has a stock Rocket 350, a/c and stock radio. What alternator do you guys recommend? Here are a couple of pictures of my current one.
TIA!
You have one of the oddball 1972 "transition" alternators. These use the 10SI case but have the guts from the 10DN external regulator alternators. When you say "replace", are you looking for a direct replacement or an upgrade?
HAHAHAHAHA
Good luck with that. Here in the mid-Atlantic, NO ONE stocks parts for starters or alternators, only rebuilt units. Yeah, they can order the parts, but why make two trips to the store when RockAuto drops them at your doorstep in a couple of days.
Heck, I just stopped at NAPA this morning. They don't even have 1.5" brass freeze plugs in stock.
You might be right Joe. I looked on rockauto and if brushes are ordered for a 72 it will be the wrong brushes. They show the earlier type for that year. I don't see a needle bearing either. He will need to look at 1973 parts (10SI) He may be better looking in ebay. Prices are cheap, but I can only guess at the quality of the bearings. I can supply them if necessary.
Thanks guys. I can NEVER find any parts locally so I will order from Rock Auto. Can you tell me if these are the correct parts from them?
SKF MNJ471S {Click Info Button for Alternate/OEM Part Numbers1974862, 2098512, 3755184, 7451326, 7451763, 7451931, 8125182, 8133267, 8134644, 9418076, 9436831, 9441879, 9451763, C3SZ10A304A, C5AF10A304A, C5AZ10A304A, C9ZZ10A304A, D20F10A304AA, D2OZ10A304A, J8125182, J8133267, J8134644} Needle Bearing Info
Commutator End (Only 11 Remaining)
$5.07 $0.00 $5.07
Electrical : Alternator / Generator Drive End BearingRelated PartsBearing Race / Seal DriverElectrical Repair ManualRelated Parts
BSKF 6203ZJ {Click Info Button for Alternate/OEM Part Numbers000625106203, 000625900174, 0023416243, 02894770, 059903221A, 07119981208, 0770620340, 0814362037, 0855960800, 106000506100, 106000506102, 11693714, 11693715, 1205210, 1205227, 1205229, 12339293, 1319349, 1893306, 19489, 2095653, 2273879, 28043180, 2894770, 3112687, 3123844, 3292201, 444197, 46600176, 636640, 659799, 700204, 707600, 707600B, 71061, 71BB10A303A, 71BB10A303AA, 7420850, 7706203, 770620340, 784808, 7848088, 8125181, 8133277, 82273879, 87600A, 9009910013, 907203, 907503, 907665, 907998, 94020008, 954290, 9921398, 9981208, A060238, A60238, A7600, A7600A1, A7600A2, B7600, B7600A, B7600A1, B7600A2, B7600A3, B7600B, B7600P, C5NN7600A, D1RY10A303A, E707600, E707600A, E7RY10A303A, E93348M, J0071061, J3112687, J3123844, J8125181, J8133277, T0620340} Ball Bearing Info
Drive End (Only 1 Remaining)
$10.42 $0.00 $10.42
Electrical : Alternator / Generator BrushRelated PartsElectrical Repair ManualRelated Parts
ASTANDARD MOTOR PRODUCTS RX99 {#1964682} Width - Inches: 5/16"; Thickness - Inches: 13/64"; Package Quantity: 2 Brushes Info
FitsExc. 63 Amp
Orwith 63 Amp
$12.57 $0.00 $12.57
SKF MNJ471S
$5.07 $0.00 $5.07
- Related Parts
- Bearing Race / Seal Driver
- Electrical Repair Manual
SKF 6203ZJ
$10.42 $0.00 $10.42
- Related Parts
FitsExc. 63 Amp
Orwith 63 Amp
$12.57 $0.00 $12.57
skf is a good brand. my personal preference on the 6203 bearing is with rubber shields, but the metal should be ok. wrong brushes. look for brushes under 1973 probably less expensive than the ones you have shown.
gearheads78
September 3rd, 2008 11:12 AM
